Rear Spacing
Gandalf the Yellow
Its is not that simple. The Deng hubs are 116mm including snail cams, the monty/tryall hubs are all 110m including snail cams. Deng mod frames are 116mm including snail cams, monty frames are 110mm including snail cams. I suppose those mod stock frames are the same as the deng mond frames. Correct me if im wrong.
almost all mod stock frames are deng anyway arent they
surely he wouldnt make parts that wouldnt go together with his different products.
mods 116mm with snail cams
mod stocks 116mm with snail cams
stock 135mm
thats the way i see it
but to answer your questions you should be able to run your profile on the mod stock, as long as it is 116mm frame and you have a tenmm axle not a 14mm axel from a bmx
Edited by python_man
