Revolver Posted January 20, 2008 Report Share Posted January 20, 2008 (edited) It doesn't work for shit.I took it off and lubed all the cables etc, but still nothing.I might see if there's some tar on the shed roof...Any suggestions? Edited January 20, 2008 by Disasterboy Quote Link to comment Share on other sites More sharing options...
mat hudson Posted January 20, 2008 Report Share Posted January 20, 2008 thankyou for that informative statement. what setup are you running? have you got even tension on the arms, are the pads aligned correctly, is your rim clean? Quote Link to comment Share on other sites More sharing options...
F-Stop Junkie Posted January 20, 2008 Report Share Posted January 20, 2008 Spelling? Punctuation? NMC isn't far away...Also, there is a BMX-Forum who may be more help! Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 20, 2008 Author Report Share Posted January 20, 2008 (edited) lolIts a tektro. All of it works except the pads. Pshhh... Edited January 20, 2008 by Disasterboy Quote Link to comment Share on other sites More sharing options...
mat hudson Posted January 20, 2008 Report Share Posted January 20, 2008 sounds like you already knew what was wrong with it. Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 20, 2008 Author Report Share Posted January 20, 2008 I did, but I thought I could get it to work.Lol, this turned out to be a useless thread , apologies for that. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted January 20, 2008 Report Share Posted January 20, 2008 I did, but I thought I could get it to work.Lol, this turned out to be a useless thread , apologies for that.yepbut seriously try pad alignment, and make sure the caliper is tightened properly, and theres no give in the nuts + bolts or anything at all Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 20, 2008 Author Report Share Posted January 20, 2008 The pads go flat against the rim. Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted January 20, 2008 Report Share Posted January 20, 2008 Could be pads, File them down so its a new surface. Get somne new pads, soft ones will be better on a smooth rim. Set the brake up correct. And also Post it the correct forum!! Quote Link to comment Share on other sites More sharing options...
Alec Posted January 20, 2008 Report Share Posted January 20, 2008 When I started riding bmx I wanted my brake to work as good as my trials bike. Stick with the crap brake, eventually you'll see you don't need plaz pads! Just takes a bit of getting used to. Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 21, 2008 Report Share Posted January 21, 2008 Grease up the brake posts and use as little spring tension as possible. That's usually the best way to get a brake to work well, but if you're shitty pads and/or a shitty brake, on a non-chrome rim, you're pretty much in the shit. Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 21, 2008 Author Report Share Posted January 21, 2008 but if you're shitty pads and/or a shitty brake, on a non-chrome rim, you're pretty much in the shit.that's exactly it. Besides, i've swapped it now I think you're the guy in the bike shop with the dropped-chainstay proto that I spoke to today lolyeah, I swapped it for an 02 t-pro, i'll get pics up once it's rideable Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 21, 2008 Report Share Posted January 21, 2008 Although I have one of the dropped stay frames, chances are that unless by "bike shop" you mean "my bedroom when I was fixing my BMX", you didn't speak to me anywhere other than here today Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 21, 2008 Author Report Share Posted January 21, 2008 weren't you then lolthere's only supposed to be 3 of those frames, i think Quote Link to comment Share on other sites More sharing options...
