Building A 36 Hole Hub Onto A 48 Hole Rim
Boswell
I have never built a wheel in my life but I want to build this 36 hole profile hub onto a 48 hole rim because I don't want to spend another £40/£50 on a new rim. Can someone please explain how I would go about doing this or post a link for instructions? :)
The main problem with trying this is that you're going to need spokes of lots of different lengths to make it work. Also have a look at the rim, the chances are every second spoke hole is offset to one side or the other of the rim. This is often needed for the spoke nipples to not bind (Lace spokes from the RH hub flange to the spoke holes offset to the RH of the rim to guarantee the spoke nipples won't bind in the rim). If you start skipping holes at random you'll end up with a weird mix of spoke angles into the rim (It'll look horrible) and the potential for binding spoke nipples. If you've never built a wheel before you'll be completely screwed trying to lace this thing, not to mind true it (I've built a lot of wheels and I would only do this as an academic exercise, definitely not as something I'd trust to use or even trust not to ruin the rim in particular (The hub should be OK, spokes and spoke nipples are cheap). £40 is more than enough to buy a decent rim for trials bikes/MTB/road bikes new - BMX stuff tends to be cheaper I'd have thought, so that rim must be unreal - is it worth buying a new hub for?
