Spoke Length Please
ZHI-sam
Go here and click on "Spokes calculator", choose anonymous usage.
Specifiy "user defined" in the rim box, then type 392 (if you've got a 20" rim) or 542 (if you've got a 26" rim) in the ERD field. Then choose Hope Pro 2 9 mm as hub, then type how many spokes you'll be using.
In "intersections" type 3 in both fields if you're going for a standard 3 cross lacing, or 0 if you'll be lacing it radial.
Click "Calculate" and the right lengths will pop up.
Cheers
Gustav
