danhalson Posted January 17, 2008 Report Share Posted January 17, 2008 hey i was wonderin what magura pads you guys use for the rear wheel i need something that has a sharp bite so the wheel dosent slip when im balancing and jumping cheers Quote Link to comment Share on other sites More sharing options...
jimmy b Posted January 17, 2008 Report Share Posted January 17, 2008 Probably the Plazmatic PMG on tarty!) Quote Link to comment Share on other sites More sharing options...
Oak T Posted January 17, 2008 Report Share Posted January 17, 2008 koxx reds they are good im using them right now. they do last pretty long aswell Quote Link to comment Share on other sites More sharing options...
max-t Posted January 17, 2008 Report Share Posted January 17, 2008 http://www.trials-forum.co.uk/forum/index....showtopic=41481 Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted January 17, 2008 Report Share Posted January 17, 2008 koxx reds im running them at the moment and i lovbe them there sharp hold well and have good where life i love them scott Quote Link to comment Share on other sites More sharing options...
tom jersey Posted January 17, 2008 Report Share Posted January 17, 2008 Blue rock pads, fooking awesome haven't warn down in about 4months and bite like a bitch! a very good buy. Quote Link to comment Share on other sites More sharing options...
bt rider Posted January 17, 2008 Report Share Posted January 17, 2008 hey i was wonderin what magura pads you guys use for the rear wheel i need something that has a sharp bite so the wheel dosent slip when im balancing and jumping cheersHeatsink reds i run them on a echo 07 with a light grind there f**king amazing. Quote Link to comment Share on other sites More sharing options...
Tim hill is a dick... yeah Posted January 17, 2008 Report Share Posted January 17, 2008 Heatsink red's on a harsh grind Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted January 17, 2008 Report Share Posted January 17, 2008 heatsink reds on a harsh or medium grind............. you will never want any other pad Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted January 17, 2008 Report Share Posted January 17, 2008 IMO Koxx blox browns. Quote Link to comment Share on other sites More sharing options...
TrAsHeR Posted January 17, 2008 Report Share Posted January 17, 2008 Phat pads for the win Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 17, 2008 Report Share Posted January 17, 2008 Plaz Crm ***!! Quote Link to comment Share on other sites More sharing options...
pengsmelly Posted January 17, 2008 Report Share Posted January 17, 2008 heatsink reds on a harsh or medium grind............. you will never want any other padhes says it how it is. Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted January 17, 2008 Report Share Posted January 17, 2008 Heatsink's are shite tbf.Wasn't impressed with mine at all.However. Rock Blue's, Medium sharp grind. Best set up ever.Danny. Quote Link to comment Share on other sites More sharing options...
Phil H Posted January 17, 2008 Report Share Posted January 17, 2008 Heatsink's are shite tbf.Wasn't impressed with mine at all.However. Rock Blue's, Medium sharp grind. Best set up ever.Danny.He speaks the truth, A mate of mine runs the rock blues and they are unbelievable and his grind is dead!I'm running some sort of plazs at the moment which are doing the job, moved from koxx browns which are also good on a grind but are completely silent if noise is your kind of thing.Phil Quote Link to comment Share on other sites More sharing options...
1000011 Posted January 17, 2008 Report Share Posted January 17, 2008 Hello.I had Zoo! Pads at one point. These were very nice pads. Although it depends on how harsh your grind is. The pads are super soft. They will wear away fairly easily.At this current moment in time. I'm using Echo pads. These are the best pads i've used. They have good hold on my warn grind with a bit of tar and dont wear down as quickly as zoosHope this helps1000011 Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 18, 2008 Report Share Posted January 18, 2008 Hello.I had Zoo! Pads at one point. These were very nice pads. Although it depends on how harsh your grind is. The pads are super soft. They will wear away fairly easily.At this current moment in time. I'm using Echo pads. These are the best pads i've used. They have good hold on my warn grind with a bit of tar and dont wear down as quickly as zoosHope this helps1000011Tar'll make any brake hold.... I use the heatsink xmas special pads...good hold, no noise, awesome in the wet and decent wear rate Quote Link to comment Share on other sites More sharing options...
Phil H Posted January 18, 2008 Report Share Posted January 18, 2008 Hello.I had Zoo! Pads at one point. These were very nice pads. Although it depends on how harsh your grind is. The pads are super soft. They will wear away fairly easily.At this current moment in time. I'm using Echo pads. These are the best pads i've used. They have good hold on my warn grind with a bit of tar and dont wear down as quickly as zoosHope this helps1000011If it needs tar im afraid to say it isn't the best choice.From my experience the deng pads are sh*t on a grind.Phil Quote Link to comment Share on other sites More sharing options...
Hope2 Posted January 18, 2008 Report Share Posted January 18, 2008 I think you should have search for a thread like this!But i would say plazmatic crm's which are what i run and are very good and give you intant bite!Bish! Quote Link to comment Share on other sites More sharing options...
Damo-adamant Posted January 18, 2008 Report Share Posted January 18, 2008 Ive used so many pads on grinds and i think that the best for locking are koxx greens on a light grind, or rock blues for the rear and rock reds for the front on light grind, and they all last a gd 4-5 months every day ridinghope that helps Damo Quote Link to comment Share on other sites More sharing options...
chris slater Posted January 23, 2008 Report Share Posted January 23, 2008 Blue rock pads, fooking awesome haven't warn down in about 4months and bite like a bitch! a very good buy.totally agree i use on my mod, they are fookin ace....serious Quote Link to comment Share on other sites More sharing options...
Onza-Trials Posted January 23, 2008 Report Share Posted January 23, 2008 Snowys in dry weather, pink gu pads in wet weather Quote Link to comment Share on other sites More sharing options...
Boswell Posted January 23, 2008 Report Share Posted January 23, 2008 Use the search! Quote Link to comment Share on other sites More sharing options...
jsy trials matt Posted January 23, 2008 Report Share Posted January 23, 2008 (edited) Blue rock pads, fooking awesome haven't warn down in about 4months and bite like a bitch! a very good buy.Tom told me to buy some after feeling his they are amazing, the bite and hold , his performance is amazing on a dead grind with tar so imagine what mine are like!!!!! ( love them) Edited January 23, 2008 by jsy trials matt Quote Link to comment Share on other sites More sharing options...
