Tyre What Pressure
SWEENY TODD
Depends what you are riding. I used to get pinch flats all the time when i fist started out but now i run my front tyre so flat i can nearly press my thumbs into the rim. :S
Rear is usually quite soft as its nice and bouncy but i will pump it up alittle if am doing a decent sized drop or something.
Hello.
I personally don't actually run a pressure from the gauge (not just because I dropped my pump and snapped the guage off in the result of it being replaced with a screw, shortly after) I just pump it until it feels too much. Then take the pump off of the valve, loosing half the air.
I do a couple of hops. Let a bit out if it feels weird. :lol:
Hope this helps,
1000011
