Boswell Posted January 15, 2008 Report Share Posted January 15, 2008 (edited) I'm trying to Install my copy of Age Of Empires III on my laptop but when i put the 1st disk in it comes up with E:\setup.exe is not a valid Win32 application, can anyone tell me the problem? Edited January 15, 2008 by Boswell Quote Link to comment Share on other sites More sharing options...
anzo Posted January 16, 2008 Report Share Posted January 16, 2008 Could be one of many things...1. Clean the disc. My guess is AOE3 is a few years old, probably had some wear and tear?2. What version of Windows are you running? If its Vista, the game may not be compatiable; usually there are patches to sort this out.3. Is the game CD-ROM based or DVD based...they're all pretty much DVD based now, are you sure your laptop has a DVD drive?Test the disc on someone elses computer; this will tell you if its a disc failure or system failure.Has the disc worked before?Try running the install manually. Go to My Computer, Right Click E:\ and click 'Explore'. Look around for 'Setup' or 'Install' file (.exe format) and try it that why...may be an autorun problem? How far do you get into the install? Do you get a menu screen or anything like that? Quote Link to comment Share on other sites More sharing options...
Joe Sheehan! Posted January 16, 2008 Report Share Posted January 16, 2008 (edited) I'm trying to Install my copy of Age Of Empires III on my laptop but when i put the 1st disk in it comes up with E:\setup.exe is not a valid Win32 application, can anyone tell me the problem?Yeah, theres your problem! Joking, as noobie as it sounds, is E:\ your cd drive, or should it be D:\ ?Reason i say this is because most lappys only have 1 HDD so that might be the problem. If not then its probably not compatible with vista. Edited January 16, 2008 by Joe Sheehan! Quote Link to comment Share on other sites More sharing options...
anzo Posted January 16, 2008 Report Share Posted January 16, 2008 (edited) It may be a problem, but I really doubt it. E:\ is an additional drive, perhaps you replaced a broken CD drive or using an external HDD and Windows will automatically issue it the next letter up. You can overcome this...Go to Control Panel, Control Panel, (Performance and Maintenance if on the gay view), Administrator tools, Computer Management, Disk Management (on the left panel), Right click the drive in question and click 'Change Drive Letter' and change the E to a D.Becareful though, some installed programs may be set to root drive E...making them inoperable if you've changed the letter. So if certain programs start causing problems, you know the reason.WARNING! IF YOU'RE USING AN EXTERNAL HDD, DO NOT CHANGE THE DRIVE LETTER! (It'll probably cause more problems than AOE3 is worth!) Edited January 16, 2008 by anzo Quote Link to comment Share on other sites More sharing options...
Maximus Posted January 16, 2008 Report Share Posted January 16, 2008 hi delete all known information of the game, i mean all, then re-install when you get it working, mabee you can play me online! Quote Link to comment Share on other sites More sharing options...
