Grind.
kenzo14
....ALL depends on what grinding disc you use as well as what pads and conditions u ride in......
muddy wet conditions wear grinds out faster then they would in the dry..
onza rims hold grinds verry verry well....use a medium compound pad ona light grind (ride say 4 days a week) will last around a month.
also depends if you ride natty as you will use your brake more than you would riding street
dave x
dave x
i would say this man knows his stuff but you can tell that by reading what he has put on here
well done yound david
x
dave x
do the pads you use make a difference?
seems strange but i'm not one to doubt you!
:D
