mairomaster Posted January 13, 2008 Report Share Posted January 13, 2008 I have magura hs-33 and it's leaking from the slave cilinders. It's filled with water + antifreeze. It's in very bad condition I have to rebleed it after every ride. Does somebody know how can I correct the problem? Quote Link to comment Share on other sites More sharing options...
Echo-Scott Posted January 13, 2008 Report Share Posted January 13, 2008 Is everything screwed in tightly? I know it may be obvious but these things can loosen off by themselves. Quote Link to comment Share on other sites More sharing options...
mairomaster Posted January 13, 2008 Author Report Share Posted January 13, 2008 Yes everiting is screwed in tightly. I think the slave cilinders needs new seals but I don't know how to take them apart so I could change the old seals with the new one? Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted January 14, 2008 Report Share Posted January 14, 2008 I have magura hs-33 and it's leaking from the slave cilinders. It's filled with water + antifreeze. It's in very bad condition I have to rebleed it after every ride. Does somebody know how can I correct the problem?I had that EXACT problemi took apart the brake, cleaned everything out, tightened everything and got a new lever!and bled it obviously!and now it''s fine!no more bleeeding after every ride anymoreyay! Quote Link to comment Share on other sites More sharing options...
