Alex Dark Posted January 11, 2008 Report Share Posted January 11, 2008 Does anybody know eher i cab get a single speed kit (16t) for a tenner?Ive found this: http://www.chainreactioncycles.com/Models.aspx?ModelID=12164And it looks to be wuite good value...recommendations? I cant spend more than a tenner inc post though.. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted January 11, 2008 Report Share Posted January 11, 2008 the woolly hat shop always had them cheap, cant find any on ebay under a tenner, may just have to bite the bullet and stump up 3 quid? or get clever and make your own spacers Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 11, 2008 Author Report Share Posted January 11, 2008 I know...woolly had them for £7.50... now they're gone so...this http://www.chainreactioncycles.com/Models.aspx?ModelID=17776 or this http://www.chainreactioncycles.com/Models.aspx?ModelID=12164 then, opinions? Quote Link to comment Share on other sites More sharing options...
Andeee Posted January 11, 2008 Report Share Posted January 11, 2008 Id advise the first one at the beggining of the post as im running that s/s kit on my echo damn good value for money you even have the odd spare spacers if your on a pro2 trial. BUY its cheaper than buying the dmr ones. Quote Link to comment Share on other sites More sharing options...
psycholist Posted January 12, 2008 Report Share Posted January 12, 2008 I wouldn't go near the singlespeed kits for trials unless you go for a sprocket with a wider base than the ones shown in the item you've linked above. Something like this http://www.tartybikes.co.uk/product.php?id=2006 - narrow sprockets will chew straight through the splines on your freehub if you use them for trials. That singlespeed kit is for use on XC singespeeders where there's a much higher gear being used and much less chain tension, so the freehub splines have a better chance of surviving. Quote Link to comment Share on other sites More sharing options...
Pashley26 Posted January 12, 2008 Report Share Posted January 12, 2008 (edited) I've got a Surley sprocket.....The DMR spacers are easily the best on the market, becouse they flare out they offer the sprocket more support.It's Beast.Jarrod Edited January 12, 2008 by Pashley26 Quote Link to comment Share on other sites More sharing options...
