liam-pantera Posted January 9, 2008 Report Share Posted January 9, 2008 hi guys well ive been using a deore v brake for about 3 weeks now and i truly hate it , some people have told me that the deore calipers were ment for no linier brakes thats why it is creating so mutch flex . Is this true or are the generaly shit brakes ? also if this is the case will using a avid series brake sort the problem , btw before anyone says its my cable or setting up its realy not .any help would be great Quote Link to comment Share on other sites More sharing options...
basher Posted January 9, 2008 Report Share Posted January 9, 2008 You using 4 bolt adaptors if so you need a booster really. Also how old is your cable and what cable is it. And by usin the adjuster at the lever that creates sponge. Quote Link to comment Share on other sites More sharing options...
Brian Bleech Posted January 9, 2008 Report Share Posted January 9, 2008 what set up do you have?The deore brakes should be fine. Flex could be coming from a number of places...Do the pads hit flat on the rim?Do you run a booster? could be the frameIs the wheel true and the spokes tight? could be the wheel flexing if the spokes are loose.What cable do you have? Quote Link to comment Share on other sites More sharing options...
Muel Posted January 9, 2008 Report Share Posted January 9, 2008 I saw a guy at a comp with no booster, it seemed pretty mint. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 9, 2008 Report Share Posted January 9, 2008 I don't have a booster on my Vee, and it's solid! Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted January 9, 2008 Author Report Share Posted January 9, 2008 its echo 2007 urban mod forks , clarks cable oiled and greased with heatsink red pads and a xtr copy lever . i can clearly see the tips of the arms flexing when i bull the brake and ive herd poor stuff about deores before Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 9, 2008 Report Share Posted January 9, 2008 Get an Avid then?SD7 would be fine... Quote Link to comment Share on other sites More sharing options...
Bigman Posted January 9, 2008 Report Share Posted January 9, 2008 My first vee setup was using dewhore caliper and it was truely awsome! almost as good as my ultimates!Adam Quote Link to comment Share on other sites More sharing options...
Hendrix Posted January 9, 2008 Report Share Posted January 9, 2008 I use a Deore on my front. It feels AMAZING and never ever ever lets go.I also use a Deore on my back, and it holds well, not at all. ha ha. Pretty much non-existent on the back! Still, I love my front one. Never gonna change it, ever Quote Link to comment Share on other sites More sharing options...
eskimo Posted January 10, 2008 Report Share Posted January 10, 2008 My Deore worked really well untill it snapped off the lugs. Quote Link to comment Share on other sites More sharing options...
