Another Crap 05 Maggy
Andrex
Well earlier today i re-bled my brake because it was going spongy and it made it worse, bled it again and now the pistons don't even move at all and the lever is really stiff, the tpa doesn't work either but i don't think thats thats the problem, had anyone got any ideas?
Are you using a syringe (bleed kit). If not then I recommend you get one. Heatsink do the syringes pretty cheap.
If the tpa doesnt work and is screwed in take off the lever, bleed it and re fit lever thats what i did.
Liam
I've tried it and there is still no hope.
The lever now pull smoothly but the pistons just don't move, I've cleaned them as well
I take both off and just keep pumping it but while it is submerged under water. It normally works
doing that wont fill the lever properly, leading to air in the brake.
You need to squeeze the lever then cover up the hole on the cylinder before you release the lever, this should suck some water into the lever, repeat a few time to be safe.
Edited by James Quigley
Submerged bleed:
Brake underwater, bleed bolts out.
Block one hole, and pump the lever, keeping the blade down.
Then unblock hole A and then block hole B.
Then release the lever, and unblock hole B and block hole A.
Repeat.
That's how I used to do it.. just wacking it underwater with no bleed bolts and pumping never worked for me? :huh:
