Michael Ingle Posted January 7, 2008 Report Share Posted January 7, 2008 I've just ordered some Infinity Kappa 6x9's, but afterwards I read about the impedance. Apparently you shouldn't run them through the head unit and they need a separate amplifier, but Ive only got a two channel amp which is built into my sub box. Basically, aside from the sound quality suffering, what would happen if I ran the 2ohm speakers from my 4ohm headunit? Am I going to blow the 6x9s / headunit? Also, if there is no alternative than to have these amped, does anyone know if its possible to remove the 2 channel amp from a Fli sub/amp box and just use that temporarily?Cheers, Mike. Quote Link to comment Share on other sites More sharing options...
Hendrix Posted January 7, 2008 Report Share Posted January 7, 2008 You won't blow them UNLESS, you crank the head unit right up.Hendrix Quote Link to comment Share on other sites More sharing options...
Pashley26 Posted January 7, 2008 Report Share Posted January 7, 2008 Two Words -Rockford Fosgatehttp://www.rockfordfosgate.com/home/Jarrod Quote Link to comment Share on other sites More sharing options...
Michael Ingle Posted January 7, 2008 Author Report Share Posted January 7, 2008 You won't blow them UNLESS, you crank the head unit right up.HendrixWhen you say all the way up, do you mean literally all the way up, or do you mean to a level which would distort average 6x9's?Also, I cant find anything on that Rockford Fosgate site which helps me Mike. Quote Link to comment Share on other sites More sharing options...
Hendrix Posted January 7, 2008 Report Share Posted January 7, 2008 When you say all the way up, do you mean literally all the way up, or do you mean to a level which would distort average 6x9's?Also, I cant find anything on that Rockford Fosgate site which helps me Mike.I meant by about half. I blew my brothers rig up, just because there was a power flux, and the speakers weren't made for the head unit. Has your head unit got a compression unit or an anti power surge unit built in ? Quote Link to comment Share on other sites More sharing options...
Michael Ingle Posted January 7, 2008 Author Report Share Posted January 7, 2008 Its a Sony Xplode so I doubt it. I might just leave them in the box until I can afford a 4 channel amp and a new sub. Dont really want to take the risk and end up blowing the speakers.Cheers, Mike. Quote Link to comment Share on other sites More sharing options...
