Callum-Luvs-Trials Posted January 7, 2008 Report Share Posted January 7, 2008 Ive got some magura mineral oil on ma rim and now my pads dont lock to my rim.I have no squeak or nothing.This has to be the fault of the oil so does any one know how i can can get it off .Would be great for your help guys.-Callum- Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 7, 2008 Report Share Posted January 7, 2008 Clean it off with a clean rag then get lighter fluid and wipe it round the rim until you see no dirt coming off the rim... the file a little of the pads so they clean..then let the brake pads wear back in again....nice tip from mrkoxx worked for me Quote Link to comment Share on other sites More sharing options...
Callum-Luvs-Trials Posted January 7, 2008 Author Report Share Posted January 7, 2008 Clean it off with a clean rag then get lighter fluid and wipe it round the rim until you see no dirt coming off the rim... the file a little of the pads so they clean..then let the brake pads wear back in again....nice tip from mrkoxx worked for me Mod-Mike your a legend thanks. Quote Link to comment Share on other sites More sharing options...
Henrik Y Posted January 7, 2008 Report Share Posted January 7, 2008 I think dish soap could work. Quote Link to comment Share on other sites More sharing options...
JoeM Posted January 7, 2008 Report Share Posted January 7, 2008 (edited) Paint thinners and a rag then you do what mod mike said. Makes your brake louder for a bit too.Edit: DON'T use white spirit as it leaves a powdery residue making the brake worse. Edited January 7, 2008 by Joeee Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted January 10, 2008 Report Share Posted January 10, 2008 Clean it off with a clean rag then get lighter fluid and wipe it round the rim until you see no dirt coming off the rim... the file a little of the pads so they clean..then let the brake pads wear back in again....nice tip from mrkoxx worked for me As above, use degreaser instead of lighter fluid. Muc-off works the best. mabye use the bike wash & give ur bike a spring clean, then ur bike will b doing this . Quote Link to comment Share on other sites More sharing options...
gundam Posted January 21, 2008 Report Share Posted January 21, 2008 try liquid degreaser and soak it if you can or try oven cleaner may work never had this problem before good luck Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 21, 2008 Report Share Posted January 21, 2008 I put nitro mots on my disc once and it worked like more oil=(so dont use that Quote Link to comment Share on other sites More sharing options...
