TrAsHeR Posted January 7, 2008 Report Share Posted January 7, 2008 (edited) Ok just need a quick help againGot my second hand freewheel and when i bought it i got told to tighten it up so here it isWhat side should I turn and what way ? Thanks ! Edited January 7, 2008 by TrAsHeR Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted January 7, 2008 Report Share Posted January 7, 2008 Is that a try-all by any chance... Well basically because the lock ring is on the other side it doesn't usually come loose as its against the crank arm, but if in your case it has then to tighten simply find a small screwdriver or rod which can fit into the two grooves and tap the ring CLOCKWISE. Alternatively you could do what I do and use a set of pliers which can fit into the groove itself. I think my dad called them fishing pliers but I dont have a clue. Quote Link to comment Share on other sites More sharing options...
TrAsHeR Posted January 7, 2008 Author Report Share Posted January 7, 2008 (edited) Yes its try all, so i should tap it on the side of the second pic right ?Edit: turns clockwise only one side. was stupid question Edited January 7, 2008 by TrAsHeR Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted January 7, 2008 Report Share Posted January 7, 2008 hellfrauds sell the tool pretty cheap,freewheel tool its called.. i think . steve Quote Link to comment Share on other sites More sharing options...
N Roach Posted January 7, 2008 Report Share Posted January 7, 2008 (edited) Picture 2: Find the two little indents, get a screw driver to grip inside one of the indents. Then hit the screw driver with a hammer, so that the lockring turns clockwise.(Do not vise the freewheel, because when I tried this my freewheel bent and the lockring became stuck.)Nathan Edited January 7, 2008 by Koxx_Nath.C Quote Link to comment Share on other sites More sharing options...
TrAsHeR Posted January 7, 2008 Author Report Share Posted January 7, 2008 Thanks but its too late ive done it went perfect Thanks Quote Link to comment Share on other sites More sharing options...
