Pluc Posted January 6, 2008 Report Share Posted January 6, 2008 (edited) Hi,I want to get the frame czar freetrials, but I'm in doubt in the brake. I prefer v-brake, but I have doubt if the adaptors will work well. I think about Heatsink V2.I'll need to use booster additional in the frame that already was built with booster?Thanks. Edited January 8, 2008 by Pluc Quote Link to comment Share on other sites More sharing options...
abtrials Posted January 6, 2008 Report Share Posted January 6, 2008 na you wont need a booster my mate ran his czar with no booster and it was fine Quote Link to comment Share on other sites More sharing options...
Pluc Posted January 8, 2008 Author Report Share Posted January 8, 2008 Hi,Thanks ABTRIALS1!Somebody more has an opinion?It can be on other frames built with booster. Quote Link to comment Share on other sites More sharing options...
2sixstreet Posted January 8, 2008 Report Share Posted January 8, 2008 I have an '06 Control with built in booster. I dont run another booster but just a booster shaped plate to protect the HS33 crossover. Quote Link to comment Share on other sites More sharing options...
abtrials Posted January 8, 2008 Report Share Posted January 8, 2008 trust me mate you will not need a booster for the fact that if the built in one ent doing enough of a job, most v bosters will not work, also depending on how wide your rim is you wont fit one on anyhow.my mate was using a 47mm rim and there is no way one would fit Quote Link to comment Share on other sites More sharing options...
Curly-Sam Posted January 8, 2008 Report Share Posted January 8, 2008 hi there i have got a echo control and i dont use onei have used a booster with it before. it dont make a differnce Quote Link to comment Share on other sites More sharing options...
Lloyd B Posted January 8, 2008 Report Share Posted January 8, 2008 as long as the frame dosent flex to much without a booster then you can run it without one but if there is alot of movment then you run the risc of your frame cracking plus a booster will make the brake feel nicer Quote Link to comment Share on other sites More sharing options...
jimmy b Posted January 10, 2008 Report Share Posted January 10, 2008 Its best to keep it to a minimum and not have a booster.It really depends on how much the frame flexxes or how the brake feels.But if you have a color themed bike eg. blue or green then go ahead and add a booster! (not that looks are more important than feel! Quote Link to comment Share on other sites More sharing options...
