Danny Kearns Posted January 4, 2008 Report Share Posted January 4, 2008 Just been having a nice casual convo with JonMack and this pops up . No idea what it means...Is it bad ? Anyone know ?Danny. Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted January 4, 2008 Report Share Posted January 4, 2008 pretty sure it's nothing to really worry about. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted January 4, 2008 Report Share Posted January 4, 2008 Its probably no help now as your probably asleep but all its done is set the page file slightly larger. The page file is a small space on your hard drive thats reserved for storing things you've told the computer to do when theres no more space on your RAM. If you were doing something intensive at the time or a random program hadn't closed properly it could have filled your RAM and paging file while windows decided it needed more room.Either way, its nothing to really worry about as the information on your RAM (if it was caused by a locked program) is lost when the computer switches off due to having no power in the RAM chips. When you turn the computer off and back on your left with fresh clean RAM.If its any consolation i usually increase my page file size in xp anyway, though now i've got vista it seems to be speeding along without such a need. Good old 64bit. Quote Link to comment Share on other sites More sharing options...
!laycky! Posted January 4, 2008 Report Share Posted January 4, 2008 Like kris was saying, maybe that or you have msn save your convos not sure how to stop it but i know that it can save convos if its set like that. Just an idea, hope i helped.cheers laky Quote Link to comment Share on other sites More sharing options...
UrbanPoet Posted January 4, 2008 Report Share Posted January 4, 2008 Like kris was saying, maybe that or you have msn save your convos not sure how to stop it but i know that it can save convos if its set like that. Just an idea, hope i helped.cheers lakyBoats is right, you are so very wrong. Quote Link to comment Share on other sites More sharing options...
Muel Posted January 4, 2008 Report Share Posted January 4, 2008 Its probably no help now as your probably asleep but all its done is set the page file slightly larger. The page file is a small space on your hard drive thats reserved for storing things you've told the computer to do when theres no more space on your RAM. If you were doing something intensive at the time or a random program hadn't closed properly it could have filled your RAM and paging file while windows decided it needed more room.Either way, its nothing to really worry about as the information on your RAM (if it was caused by a locked program) is lost when the computer switches off due to having no power in the RAM chips. When you turn the computer off and back on your left with fresh clean RAM.If its any consolation i usually increase my page file size in xp anyway, though now i've got vista it seems to be speeding along without such a need. Good old 64bit.Oooohh Kris has made the jump! 64 bit, it's the only way to go.I have XP SP3 on my spare comp. Yeh that's right, SP3! It's a leaked copy apparently. Anyway, there is no difference at all to SP2 I can see, apart from it is noticably faster. When SP3's official release comes about, it'll be running on this one aswell. Don't want to risk it though, a leaked, pre-beta copy could have so much shite on it.Am I right in thinking that more RAM would help to solve Danny's problem? I need more, when you watch the little graphs in mine, if I have 2 programs or more open, the RAM is flatlining. 512mb ***! Quote Link to comment Share on other sites More sharing options...
UrbanPoet Posted January 4, 2008 Report Share Posted January 4, 2008 A release candidate of SP3 is already publically available, and I doubt your "leaked" copy is "pre-beta". As for the RAM, more will help Kearns' situation, so will a good OS cleanup/format! Quote Link to comment Share on other sites More sharing options...
Wet Banana Posted January 4, 2008 Report Share Posted January 4, 2008 Means you should turn it off more often.Restart it and you'll be alright. Quote Link to comment Share on other sites More sharing options...
spode@thinkbikes Posted January 4, 2008 Report Share Posted January 4, 2008 A fixed size Swap File will perform better than a dynamically expanding one too. I would: - turn the swap file OFF. - restart into safe mode. - defrag the computer. - boot up normally, turn swap file back on to a fixed amount. Probably 1GB.Or, if you're not fussed - that error is nothing to worry about, and you can just carry on as normal. But yeah, it's a sign that you could probably do with a little more RAM, or that something you've got running is chewing it all up! Quote Link to comment Share on other sites More sharing options...
JT! Posted January 4, 2008 Report Share Posted January 4, 2008 That's what happens when you talk to JonMack on msn. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted January 4, 2008 Report Share Posted January 4, 2008 Oooohh Kris has made the jump! 64 bit, it's the only way to go.I have XP SP3 on my spare comp. Yeh that's right, SP3! It's a leaked copy apparently. Anyway, there is no difference at all to SP2 I can see, apart from it is noticably faster. When SP3's official release comes about, it'll be running on this one aswell. Don't want to risk it though, a leaked, pre-beta copy could have so much shite on it.Am I right in thinking that more RAM would help to solve Danny's problem? I need more, when you watch the little graphs in mine, if I have 2 programs or more open, the RAM is flatlining. 512mb ***!Thought i'd give the 64bit vista a try yeah, it seems good. Its noticeably faster than the 32bit version i tried a while back, when i say noticeably, i mean that it doesn't seem to hang like the old one did and swapping numerous amounts of files from one place to another isn't a problem now either. The speed for opening photo album folders and stuff seems quicker too. I also like how much more intuitive it is with regards to installing new devices. It picked my camera, webcam and mobile phone up straight away and had them setup with the right drivers within a matter of seconds. It was more of a hit and miss case with XP especially with it finding my camera, it'd often tell me there was a problem with the device and it may not be working properly. Not had any incompatability issues yet with games and things eaither so thats nice, games seem about the same speed too, though i dropped 2-3fps in crysis with vista. I think when i get my new hard drive i'll make the change permanent instead of a dualboot with xp.More RAM is always good, especially now you can pick up 2gb of ddr2 for less than £30. I bought some, got gold heatsinks and everything... looks great and performs really well too. My vista index score is 5.2, and thats because my hard drive is shit Everything else is 5.7-5.9 so my computer is right up there The £30 ram got full vista marks at 5.9 too so it'd be worth picking up if you can fit ddr2. Quote Link to comment Share on other sites More sharing options...
Danny Posted January 4, 2008 Report Share Posted January 4, 2008 My vista index score is 5.2, and thats because my hard drive is shit Everything else is 5.7-5.9 so my computer is right up there The £30 ram got full vista marks at 5.9 too so it'd be worth picking up if you can fit ddr2.Ner ner mines 5.7Anyway how much ram do you actually have? You should consider getting some more but still you really shouldn't be seeing that message with only that number of programs open. Is your hard disk full? Quote Link to comment Share on other sites More sharing options...
JonMack Posted January 4, 2008 Report Share Posted January 4, 2008 256MB Quote Link to comment Share on other sites More sharing options...
Krisboats Posted January 4, 2008 Report Share Posted January 4, 2008 (edited) Ner ner mines 5.7Bet you paid for your vista too didn't you... same here... maybe.... My next lowest is 5.7, thats the processor. Damn e2180 being slow, i expected more than that speed out of it for £45 Can't complain too much i guess though, i am a poor student and it beats a non-OC'd e6850 in every test i've tried Edited January 4, 2008 by Krisboats Quote Link to comment Share on other sites More sharing options...
JonMack Posted January 4, 2008 Report Share Posted January 4, 2008 Firefox has tabs for a reason Quote Link to comment Share on other sites More sharing options...
Krisboats Posted January 5, 2008 Report Share Posted January 5, 2008 Firefox has tabs for a reason Yeah i know, its to royally annoy me as i close 4-5 "pages" at once. Quote Link to comment Share on other sites More sharing options...
MadManMike Posted January 5, 2008 Report Share Posted January 5, 2008 Yeah i know, its to royally annoy me as i close 4-5 "pages" at once. You'll do that twice at max before you learn better. Honestly! Quote Link to comment Share on other sites More sharing options...
br3n Posted January 5, 2008 Report Share Posted January 5, 2008 my vista score is 4.7 (graphics)Highest rank 5.1 on primary hard disk, strange as its a laptop so will only be 5400rpm :/ is sata though :/Anyone else got laptop scores? bit disapointed. Quote Link to comment Share on other sites More sharing options...
