Calling All Cnc / Metal Works / Machinists Etc.
Andy P
Andy,
the_soon_to_be or dave85 will be your best bet to get in contact with.
How many horses are hidden in your Volvo now then?
edit: You might want to measure where all the holes need to be ;)
Cheers,
The Volvo is currently producing about 0 bhp and has been for the past 4 months or so lol. Its been off the road for a while now - for bigger and better things :)
How my workshop looks at the moment!!!
The PDF is 1:1 scale but if required I'll put up all the measurements up.
Andy P
I think you'll need to before anyone will be able to make it. The dimensions your using are exact, there are no tolerances in your drawing, i'd imagine something small like half a mill either way would be ok, but in certainley no expert!
Are you sure mate? Only reason I mentioned it was because seemed way off, ie the 57.1mm gives me about 75 mm. It may be my printer is mental but shouldn't be that far off.
The tolerances dont have to be as exact as I've listed. the exhaust ports for example can be a few mm smaller than shown because at the end of the day I'll be matching them to the head (which will also be ported).
The scale is 1:1 @ A3.
Andy
Just double checked in Illustrator and it's 1:1 at A3 like Andy said.
Andy
As I said, you havnt used any tolerances.
http://engineering.dartmouth.edu/mshop/pdf/introdr.pdf
Page 11 shows what i'm on about.
True although as I've said it dosent have to be exact. The measurements I've given have been adapted from inches hence all the decimal numbers. The exhaust ports can be smaller (1-2mm), but not larger. The bolt holes would obviously be 9mm (for a M8 bolt) so a +-0.5mm tolerance on bolt centres. External dimensions (the actual plate size) do not require such a tolerance, so long as there is sufficient material for welds - at a guess I'd say +-3mm.
Andy
