Component Car Speaker Help
SamHolmes
Right, need some speaker help and someone must know on here
Before I order anything I want to know a few things.. Im already running a sub into a 4-channel amp so everything is already wired up
If I was to order this what else would I need, like any other cables,esc?
And when wireing it all up, would I only need to wire the cables from the crossovers into the amp after connecting the tweeters and woofer into the crossover? would I need to wire anything else up?
Cheers for any help, I have posted on other forums but taking a while to get a reply
wires go from amp to the +/- on the crossover as if they were a speaker terminal..
from the crossover you have 2 cables (+/-) going to the speaker and 2 (+/-) to the tweeter.
so you need cables from headunit/amp to crossover, then cables from there to tweeter AND speaker.
Edited by br3n
