PaRtZ Posted January 1, 2008 Report Share Posted January 1, 2008 I'm now running a hollow starnut setup so that my cable runs through my forks, and it worked really well. Now I say worked because for some reason the last couple of rides I brought it out and its just lost all of its power! No bite or hold at all, cant even stop me when I trackstand....Now I don't know why its happening because here are my answers so far:Its not contaminationIts not bad setup (doing the wind the outer pad adjuster in, tighten slotted bolts, unwind adjuster method to set it up)Its not pad wear because this happened all of a sudden, my front wheel was out and the bike was in the carIts not the rotor; all the bolts are tightNow it might the cable routing, for some reason my BB7 was really weird and never seemed very smooth (perhaps time to upgrade...) but now its getting silly. Any other ideas? Im running out...Thanks guys Quote Link to comment Share on other sites More sharing options...
Al_Fel Posted January 1, 2008 Report Share Posted January 1, 2008 maybe when you set it up the wheel was in on a slight angle so when you've taken the wheel out and put it back in again its gone straight but the caliper is set up wrong. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted January 1, 2008 Author Report Share Posted January 1, 2008 maybe when you set it up the wheel was in on a slight angle so when you've taken the wheel out and put it back in again its gone straight but the caliper is set up wrong.good try, but i've taken the wheel out and tightened it up in 4 different positions with different tightnesses. Still seems god awful!Keep them coming though Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted January 1, 2008 Report Share Posted January 1, 2008 This may sound a silly one but just chuck some water over the disc this same thing happend to me so i threw some water over the disc and then some mud a just dragged the brake and it was mint again Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted January 1, 2008 Report Share Posted January 1, 2008 if the bend in your cable is to sharp it may not pull enough cable through they system to lock the break try running it without the hollow steerer . Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted January 1, 2008 Report Share Posted January 1, 2008 Is the arm on the caliper bottoming out? Quote Link to comment Share on other sites More sharing options...
smoke257 Posted January 2, 2008 Report Share Posted January 2, 2008 Try running it with out putting it trought the star nut, so theres no cinks or bends atall, maybe even try a new cable. So you can see if the cable is the problem, also like said above, water works a treat Quote Link to comment Share on other sites More sharing options...
Jason222 Posted January 2, 2008 Report Share Posted January 2, 2008 (edited) I've had this EXACT same problem. You can do 2 things:1. Take wd40 or some other kind of spray lubricant and spray the inside of your housing and some of the cable. Don't get any of this shite on your rotor or pads though.2. Replace the housing and cable.Also make sure that you're not using derailleur housings. Edited January 2, 2008 by Jason222 Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 3, 2008 Report Share Posted January 3, 2008 Mine did this a while back.. Turned out I pulled the lever too hard/didn't tighten the cable up enough, and the cable just slipped a bit. So it wasn't pulling it enough.Try loosening the cable and see if you can pull it through anymore... Quote Link to comment Share on other sites More sharing options...
Tom_ Posted January 3, 2008 Report Share Posted January 3, 2008 my bb7s always been wierd and kinda spongey aswell, i dunno it locks and stuff but feels almost like a maggy with air int system.:/ Quote Link to comment Share on other sites More sharing options...
Elmo =) Posted January 3, 2008 Report Share Posted January 3, 2008 my mates did this a few days ago, he was riding it then he stoped to have a rest ( no one fiddled wih hes brake) he got back on and it just didnt work. he chucked some water over it and it was fine.maybe the ghost of bb7 is out and about Quote Link to comment Share on other sites More sharing options...
