Kobikes Rims...
Grant Hundley
drilled or cnc squares
199 members have voted
  1. 1. what would you have?
    • drilled
      51
    • cnc'd
      148
been speaking to dan ko and he said he may do his kobike rims like the old echo 05 rims.. with the cnc'd squares
he's not really convinced many people will buy them as the new trend is to have drilled rims
so tell me what you'd rather have, drilled or cnc'd squares
heres a pic of the cnc rims...
them rims all the way been wanting a piar for yonks make sure he does them in 36 holem for my profile:D
and 32 lol for front hub
yer cnc'd all the way crack on i say!
Id like cnc'd! There is already a wide range of drilled rims.
Incorrect.
They are all the same rim, made out of the same material with the same dimensions etc. unfortunately...
But, i would like a rim that is good for grinding like the Echo's but in a 36 hole model!
Cheers,
Joe.
QUOTE (joe b @ Jan 3 2008, 01:02 AM) <{POST_SNAPBACK}>
Incorrect.
Cheers,
Joe.
Dont they make echo 07 rims in 36h now ?
Incorrect.
Cheers,
Joe.
Get with the times joe ;), they come int 36h now.
EDIT: make the -05 echo tyres too ;).
Matx
Edited by Mat Smith!!!!!!!!!!!!!!!!!
Official Information:
The KO Rims will come CNC'd and front rims will be 38mm (Front) and 44mm (Rear)
Features:
Sizes: 26" (Front + Rear), 20", 19" (Front + Rear)
Drillings: Front 32H Only, Rear 32H and 36H
Finish: Anadised Black and powder coated white and (Possibly anodised orange aswell)
I hope this will answer everyones questions:)
Thanks
Dan
PS: If you have any questions about it, or any suggestions please post and I will make a note of it all:) (Always best to produce products from riders point of view, rather then producing for them:) )
Edited by Dan@Trials-uk
Bring out the same style rim like the old skool planet x bmf's or the onza half fat rims they were non drilled or anything they were chunky but not chunky like a try-all i think the rears worked out at like 38-39mm wide. If you did that in cnc'ed or something except drilled as trials manufacturers are bringing out drilled rims and its very boring.
Bring back the BMF'S!!!!
Features:
Thanks
Dan
sounds good so far,if its possible i reckon eyeletted rims will be cool (Y)
steve
Features:
Thanks
Dan
Leg-end! :rolleyes:
The rims will indeed come with anodised/ powder coated side walls:) Eyelets will be part of the rims feature :) I will look into the 24" option ;) Maybe a few limited runs
Drilled side walls: I thought about this today, Possibilities on 2 models for the front rim, 1 disk only and the other front rim brake :)
1, Rim Brake Version: colour sidewall
2, Disk Version: Rounded/ colour sidewall/ Drilled sidewall (Not confirmed)
Tyres: I am looking into these and hopefully Kobikes will bring these out :) - More update on a later date for the tyres (20" only!)
