Guest rob Posted September 4, 2003 Report Share Posted September 4, 2003 :- can u help me I dont no how to put pedels in Quote Link to comment Share on other sites More sharing options...
Joe Papasnap Maher Posted September 4, 2003 Report Share Posted September 4, 2003 pedAls look on the bottom of the bottom, near where thread is, and it should either have r or l on meaning right or left. So for the one with r on you put it into your right hand crank with a 15 mm spanner turning clockwise, then with the l one u put it on the left hand side crank anti-clockwise I hope this helps Quote Link to comment Share on other sites More sharing options...
joe_cambs Posted September 5, 2003 Report Share Posted September 5, 2003 Remember that they are reverse threaded, so to take them off you undo them the way you would normally tighten something up, and vice versa. Usually helps if someone holds the pedals still as you take them off, cause they make the cranks go round. :- Joe. Quote Link to comment Share on other sites More sharing options...
Tartridge Posted September 5, 2003 Report Share Posted September 5, 2003 Right pedal goes in clockwise. Left pedal goes in anti-clockwise. (Why? To help stop them working themselves loose) Easy way: Put crank arm facing upwards, and attach spanner facing upwards too. Fowards = tighten, backwards = loosen. Quote Link to comment Share on other sites More sharing options...
TrialsDisplay.co.uk Posted September 5, 2003 Report Share Posted September 5, 2003 Put a bit of grease on the thread aswell. :thumbsup: Quote Link to comment Share on other sites More sharing options...
Trebor Posted September 5, 2003 Report Share Posted September 5, 2003 Wha? The confusion! I used to be 'rob' Quote Link to comment Share on other sites More sharing options...
Tomm Posted September 6, 2003 Report Share Posted September 6, 2003 And now you aren't... Quote Link to comment Share on other sites More sharing options...
Guest Al_Fel Posted September 6, 2003 Report Share Posted September 6, 2003 How me make wheel work? Me want fire to make big burny burn. Quote Link to comment Share on other sites More sharing options...
MattOnTheBmix Posted September 30, 2003 Report Share Posted September 30, 2003 lefty loosey righty tighty is how I rember it! but remember that the left one is lefty tighty righty loosey(I think) I work in a bike shop as a mechanic ud think id no!!! Quote Link to comment Share on other sites More sharing options...
