rudirudirudirudirudi Posted December 28, 2007 Report Share Posted December 28, 2007 (edited) ok, just been taking my bike apart ready to swap parts to my adamant. its got an echo headset, between the top cup and the steerer there is a little alliminium( i think) washer. i have no idea how to take it out. someone help me please. thanks Edited December 28, 2007 by rudoxolty Quote Link to comment Share on other sites More sharing options...
abtrials Posted December 28, 2007 Report Share Posted December 28, 2007 use a hammer and hit the top of the fork stear tube this will loosen the washer then you should just be able to pull it off Quote Link to comment Share on other sites More sharing options...
psycholist Posted December 28, 2007 Report Share Posted December 28, 2007 Try tapping the top of the fork steerer with a mallet (Not a metal headed hammer). Once the fork starts moving everything should come apart quite easily. Remove the stem and all the spacers on the steerer before doing this. Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted December 28, 2007 Author Report Share Posted December 28, 2007 use a hammer and hit the top of the fork stear tube this will loosen the washer then you should just be able to pull it off i tryed hitting it a bit, guess ill have to put more beans into it.ok, i just went and picked up the frame and the forks just fell out. lol. instead of making another topic, iv got out one of the headset cups. but the other one isnt coming out. it doesnt even seem to be loosening. any ideas?Heat the frame and just hit the shit into it. Didn't read the rest of the topic but you're using a screwdriver and hammer yer? If so just keep beating into it. yep, screwdriver and hammer. heat the frame with what. Quote Link to comment Share on other sites More sharing options...
Fishy Posted December 28, 2007 Report Share Posted December 28, 2007 Blowtorch or heatgun. Expands the frame making it easier to wack out. Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted December 28, 2007 Author Report Share Posted December 28, 2007 Blowtorch or heatgun. Expands the frame making it easier to wack out. yer ummm, i dont have either. would anyone advise getting a headset rocket??? Quote Link to comment Share on other sites More sharing options...
Fishy Posted December 28, 2007 Report Share Posted December 28, 2007 (edited) OOOOOOOOOOOOOOOOOH, You mean the thing that holds your forks in?Just get a screwdriver and ease it out. I thought you meant the cups.Edit: Look around it because there should be like a slot you can put a screwdriver in, then like try and lever it out. Edited December 28, 2007 by Mr Fish Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted December 28, 2007 Author Report Share Posted December 28, 2007 OOOOOOOOOOOOOOOOOH, You mean the thing that holds your forks in?Just get a screwdriver and ease it out. I thought you meant the cups.Edit: Look around it because there should be like a slot you can put a screwdriver in, then like try and lever it out. no, i am talking about the cups now. i was originally talking about that washer thingy, but thats all sorted now. any other ideas for getting the cups out??? Quote Link to comment Share on other sites More sharing options...
Fishy Posted December 28, 2007 Report Share Posted December 28, 2007 Took me like an hour to get my bottom one out my frame. Just keep wacking it to f**k.Tap your frame with the hammer above your cups. if that makes sense? Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted December 28, 2007 Author Report Share Posted December 28, 2007 Took me like an hour to get my bottom one out my frame. Just keep wacking it to f**k.Tap your frame with the hammer above your cups. if that makes sense? this is stupid, iv just used a fat off screwdriver and a beast of a mallet and been twating the thing. hasnt budged one bit. Quote Link to comment Share on other sites More sharing options...
Fishy Posted December 28, 2007 Report Share Posted December 28, 2007 Tapped your frame? Tap it all around and you like moving the screwdriver around so you aren't just hitting the same bit? Quote Link to comment Share on other sites More sharing options...
rudirudirudirudirudi Posted December 28, 2007 Author Report Share Posted December 28, 2007 yay!! never worked so hard in my life but it was worth it. now im fookin nakered. inside is soooo meesed up. made me laugh. cheers guys for all your help. rudi. Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted December 28, 2007 Report Share Posted December 28, 2007 f**king twat it rudi u wimp Quote Link to comment Share on other sites More sharing options...
Danny Posted December 28, 2007 Report Share Posted December 28, 2007 Get an old seatpost and cut 2/4 slots in it so the bottom few inches are cut into 4/8 equal sections. Bend em out a bit until you have a crude version of this http://www.tartybikes.co.uk/product.php?id=627Please ignore Mr Fish and don't heat it up. Quote Link to comment Share on other sites More sharing options...
Fishy Posted December 28, 2007 Report Share Posted December 28, 2007 (edited) Why not?Same concept for removing your bottom bracket? Edited December 28, 2007 by Mr Fish Quote Link to comment Share on other sites More sharing options...
Revolver Posted December 28, 2007 Report Share Posted December 28, 2007 it might just do some permanent damage if you heat itMIGHTthat rocket thing looks good. Normally i use a screwdriver. Quote Link to comment Share on other sites More sharing options...
Fishy Posted December 28, 2007 Report Share Posted December 28, 2007 it might just do some permanent damage if you heat itMIGHTthat rocket thing looks good. Normally i use a screwdriver.Oh right, like flare the headtube? Quote Link to comment Share on other sites More sharing options...
Revolver Posted December 28, 2007 Report Share Posted December 28, 2007 something like thatcus if it's hot enought to expand, its also hot enough to be easier to damage Quote Link to comment Share on other sites More sharing options...
Fishy Posted December 28, 2007 Report Share Posted December 28, 2007 Ah, that might be why on my t-raptor the headset just pulled out with my hands haha. Quote Link to comment Share on other sites More sharing options...
