DANNI BOI Posted December 26, 2007 Report Share Posted December 26, 2007 i have a last years onza t pro with an oversized bottom bracket and i snappes the bottom bracket which was in it!so i decided to get a new bottom bracket and put it in!it was all fine till i realise the tread was coming out of the frameso now i am eft with on side of my frame threadless!!!!what do u rekon i soould do??well what options doi hav of gettin my frame up and running again??please could someone just give me a tip or put me in the right drectuion?? Quote Link to comment Share on other sites More sharing options...
Ladd Posted December 26, 2007 Report Share Posted December 26, 2007 (edited) Threadless bottom bracket ?EDIT : something along the lines of this: Threadless Edited December 26, 2007 by Mod-Mike Quote Link to comment Share on other sites More sharing options...
gussie Posted December 27, 2007 Report Share Posted December 27, 2007 depends how badly the threads are damaged but tartybikes will use tap or die (can't remember which tool it is) on the frame which means they will re-thread the bottom bracket hole/space (can't think of the proper name). thus you will then be able to install a bottom bracket again.hope this wasn't to late as you may have bought a new one already but if not hope it was helpful.gusgus Quote Link to comment Share on other sites More sharing options...
sam ere luvin :Ptrials:P Posted December 28, 2007 Report Share Posted December 28, 2007 (edited) little Sam way. either bodge it in with ptfe tape and will be ok or bodge it in with araldite wont come loose then exact same happened with mine Edited December 28, 2007 by sam ere luvin :Ptrials:P Quote Link to comment Share on other sites More sharing options...
Ladd Posted December 29, 2007 Report Share Posted December 29, 2007 depends how badly the threads are damaged but tartybikes will use tap or die (can't remember which tool it is) on the frame which means they will re-thread the bottom bracket hole/space (can't think of the proper name). thus you will then be able to install a bottom bracket again.hope this wasn't to late as you may have bought a new one already but if not hope it was helpful.gusgusTarty dont re-thread frames and if you look at the description of bottm bracket tapping its is only cleaning the threads out so the bottom bracket goes in super smooth when going in , threadless bb *** , or get it tapped out bigger and have a insert put it to take the bottom bracket Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted December 29, 2007 Report Share Posted December 29, 2007 Araildite Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted December 29, 2007 Report Share Posted December 29, 2007 Arailditeyep stick the f**ker in thear use super glue string and match sticks.....works a treat Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 1, 2008 Report Share Posted January 1, 2008 yep stick the f**ker in thear use super glue string and match sticks.....works a treat And if he wants to get it out again ? Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted January 1, 2008 Report Share Posted January 1, 2008 I wouldnt piss about with it , get it re-threaded some where if it does it again just buy a new frame -preferablery not a t-pro lol Quote Link to comment Share on other sites More sharing options...
*Tom* Posted January 1, 2008 Report Share Posted January 1, 2008 (edited) Nice to see you on the forum Dan mate As said above just araldite it in, if not im sure ollie will think of a way to bodge it. lol. Edited January 1, 2008 by *Tom* Quote Link to comment Share on other sites More sharing options...
Modjames Posted January 9, 2008 Report Share Posted January 9, 2008 (edited) hi i my mate has used super glue and that seems to have held it but u have to cover it in the stuff Edited January 9, 2008 by Modjames Quote Link to comment Share on other sites More sharing options...
I (HEART) Trials Posted January 10, 2008 Report Share Posted January 10, 2008 you could get it helicoiled but i recomend getting it tapped Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 11, 2008 Report Share Posted January 11, 2008 you could get it helicoiled but i recomend getting it tapped i dont think theres a helicoil kit for that size that does that fine a thread.....yu see, bike threads are very fine to stop bits shking loose etc..However, you could probably get an insert machined for it...then get the bb tapped to fit the insert? Quote Link to comment Share on other sites More sharing options...
basher Posted January 11, 2008 Report Share Posted January 11, 2008 (edited) Your options are, glue the bottom bracket in, or get a company to put a metal insert in which will cost about 50-80quid i think. I would just save for a new frame and glue the bb in for now. You cant re tap it as think about it if the threads gone the hole is technically bigger so when you try tapping you will either be tapping hardly any material at all or fresh air. If you drilled the thread out of a magura mount on your frame the bolt would just go in and fall. If you stick a tap in you cant tap it as the hole is bigger as a tap cuts material away leaving the thread you would have to add material to the hole somehow, so stop saying get it retapped just think about it first.edit: you cant helicoil it Edited January 11, 2008 by basher Quote Link to comment Share on other sites More sharing options...
jimmy b Posted January 11, 2008 Report Share Posted January 11, 2008 If i was you and i had enough dosh then id probably get a new frame! Theres loads out there and if you get validated soon you could probably pick up a decent one for £50 on TF! Quote Link to comment Share on other sites More sharing options...
DANNI BOI Posted January 14, 2008 Author Report Share Posted January 14, 2008 ok thanks people well i tryed the glueing it in option ... and we will soon see if it has worked i will let you no soon peoplethanks everyone! Quote Link to comment Share on other sites More sharing options...
