b*****d Hs33
Revolver
today, i pulled my lever and summat weird happened, and there was a sound and then the lever started to pull all the way in. It lost a lot of power, for e.g, it used to pull in maybe 1/2 way to fully lock, now it pulls in all the way and doesn't fully lock. It can't be fluid leaking because i checked the hose and there's no obvious signs of leakage.
what do u reckon's happened?
more importantly, how do i fix it?
the tpa is exactly the same as it was before, which was, broke lol (cross threaded)
possibly the mount slipped on one of the pistons, but the other one didn't and it's also acting a bit funny.
might i add, the lever is really slow to return to fully out, and if you pump it quickly, a small amount of slack occurs, and the lever goes lose for half a sec.
My mates magura done this the oother day he pulled it to hard , so the calipers moved a tiny bit but i reset the brake , and it is still really loose and the tpa is fine , im just going to rebleed it and see what happens(Y)
