chris slater Posted December 23, 2007 Report Share Posted December 23, 2007 Hi guys, Only just started useing snail cams and not really sure if i have them set right Can anyone help me or post some pics of how they should look wen setup?Thanks alot...Chris Quote Link to comment Share on other sites More sharing options...
Mike Winton. Posted December 23, 2007 Report Share Posted December 23, 2007 as long as your wheel in central and your chain is tight it doesn`t really matter Quote Link to comment Share on other sites More sharing options...
chris slater Posted December 23, 2007 Author Report Share Posted December 23, 2007 as long as your wheel in central and your chain is tight it doesn`t really matter looks like i got it right then Thought there might have been some tech way that everyone else does it lol..Thanks alot Quote Link to comment Share on other sites More sharing options...
JonMack Posted December 23, 2007 Report Share Posted December 23, 2007 I put them so that to tension the chain I push them down, that way I can stamp on them to get them that little bit tighter. Quote Link to comment Share on other sites More sharing options...
psycholist Posted December 24, 2007 Report Share Posted December 24, 2007 The chain shouldn't need to be that tight - it'll feel pretty horrible while you're pedalling (Or rolling as well if you've a front freewheel). It should be just short of taut. It's usually a good plan to have the cams in matching positions on both sides of the frame. This should mean that the back axle is straight in the frame so the rim will run straight in the frame (It may need redishing or your frame alignment may be off if the wheel is obviously out of line with both cams adjusted to the same position). The chain line will also be straight, leading to quieter running, less chain wear and less chance of the chain hopping under load. Quote Link to comment Share on other sites More sharing options...
JonMack Posted December 24, 2007 Report Share Posted December 24, 2007 I dunno if that was aimed at me but I'm well aware of the problems with running an extremely high tensioned chain.Thanks anyway. Quote Link to comment Share on other sites More sharing options...
JT! Posted December 24, 2007 Report Share Posted December 24, 2007 If i turn my cams by hand, i can never get the chain anywhere near as tight as i like it.Mole grips clamaped onto the end help get the rest of the way though. Quote Link to comment Share on other sites More sharing options...
JonMack Posted December 24, 2007 Report Share Posted December 24, 2007 Same here, but I still prefer the stomp Quote Link to comment Share on other sites More sharing options...
esfrost Posted December 24, 2007 Report Share Posted December 24, 2007 I have been using my chain really tight for more than two years now, and i have never had any kind of probelem with it. It gives me a really instant feel... Quote Link to comment Share on other sites More sharing options...
Zordon Posted December 24, 2007 Report Share Posted December 24, 2007 I've been using my current chain for 6 months now on my GU '06 20' frame with echo snail cams. They are pretty small compared to other cams and now the chain is so stretched that I cannot tighten it by cams anymore. I guess it's the right time to replace the chain then. Quote Link to comment Share on other sites More sharing options...
JonMack Posted December 24, 2007 Report Share Posted December 24, 2007 I assume it's not loose enough to be able to take a link out? But replacing the chain sounds like a good idea anyway Quote Link to comment Share on other sites More sharing options...
