Problem With Chain Tension
Lloyd B
my freind just brought a mod with a front feewheel and square taper cranks and wen i pedal the chain goes realy loose then realy tight again ive made sure the wheel is striat and the snail cams are eaqual and i cant think what the problem is as its a brand new bb so i doubt its bent
please help, lloyd
hi mate. has the bike been stood for any decent period of time?? i had a similar problem a while back. i started with freewheel, stripped it,cleaned and re-greased it. didnt solve the prob. took the axle out of the rear wheel and found the drive side of the hub had worn quite abit becoming an egg shape allowing the hub to move around. bought a new wheel and not had a prob since.
checked your chain for stiff links?
this happend to my t-bird it obvioulsy hadnt been kept well as there was loads of tight spots
in the chain so it could be that? i solved this by taking the chain off and coating it in lube and leaving it for a day
it worked... if thats any help
jake
you just put what i said into more words.. lol
my mates try-all does this but when its tight it is super tight but when its loose you can take the chain off with your hands ! and the cranks freewheel chain rear sprocket is all new , the only thing is the bb mite be bent :D
