How To
dirt jumper jake
I'm not a mod man but you can definately get the wheel off without bothering the maggies, just de-flate the tyre completely and pull the wheel off :)
im sure someone can give you some advice on the tensioners, i'd just fully undo them and then they'll come off with the wheel.
1. Deflate the tyre until you can push is past the maggies with out touching them.
2. Loosen the tensioners ( this is if your using onza or simular ? Not snail cams ) There is no need to take the peice of metal completly off.
3. Undo the two axel bolts
4. Pull the wheel genterly back. ( you might want to take the pads off ? they just pull out and back in. ) Follow the dropouts and then you will have your wheel completly off.
(Y) Hope this helps :D
Swap 2 and 3 around, and thats how i would do it :D
