Crank Bolt Not Drilling Out..... Now What
Toby3448
the crank bolt wont drill out and i plan to sell my bike this week , iv got the new bolts and the easy out tool but my drill seems to only scruff the bolt .
is there a trick to it or any other solution
quick response needed
Edited by Toby3448
Most crank bolts are hardened steel, so a lot of drill bits, even those rated for steel, will take a long time to cut into them. Put oil or cutting compound into the hole as you drill to stop the drill bit overheating and losing it's edge. I cracked an easyout trying to get a crank bolt out of a set of DMR chieftans, so if the bolt is properly seized there's no guarantee easy outs will work. Sawing the BB axle or the crank (Depending what you want to keep) may be your only option.
If it really is stuck, take it to a garage (the dodgy back street ones will probably be the best) and get them to use their oxy-acetylene burning gear on it. Some heat will soften it enough to drill. If that doesnt work then the bolt can be burnt completely out (with no damage to the axle).
