Ben John-Hynes Posted December 12, 2007 Report Share Posted December 12, 2007 Heywas wondering how often you usually bleed your hs33's?as i bled mine the other day,they felt for for around a weekand they now feel as though there is air in them.cheers guysBenx Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted December 12, 2007 Report Share Posted December 12, 2007 whenever they start to feel a bit crappy,usually every 6weeks or so.are you bleeding with water or oil mate? Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted December 12, 2007 Report Share Posted December 12, 2007 Heywas wondering how often you usually bleed your hs33's?as i bled mine the other day,they felt for for around a weekand they now feel as though there is air in them.cheers guysBenxDid you leave the tpa wound on? I just bleed mine when it needs done Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted December 12, 2007 Author Report Share Posted December 12, 2007 used water this timemay try baby oil next timeas wiki says it's a good option,what you think? Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted December 12, 2007 Report Share Posted December 12, 2007 Got my 1st Magura in about 2004-2005, had it untill about 2006. Then bled it with water. After that NOTHING BUT TROUBLE. Got a brand new one. been good since, That was late 2006. Never been bled, well okay once at the factory Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted December 12, 2007 Author Report Share Posted December 12, 2007 Did you leave the tpa wound on?i made sure it was twisted all the way around,why does the TPA affect it? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted December 12, 2007 Report Share Posted December 12, 2007 havn't bled mine for about 3 months, i only bleed it when it royally f**ks up. Quote Link to comment Share on other sites More sharing options...
psycholist Posted December 12, 2007 Report Share Posted December 12, 2007 Haven't bled my Maguras since about 2001... I have replaced most of the lever internals (TPA bushings, pushrods to the pistons and threaded bolt from the TPA knob have all been mashed from use and replaced at least once and the brake still doesn't leak. Try using Magura oil (Or failing that try Citroen suspension fluid - LHM oil). No problems at all with leakage. Quote Link to comment Share on other sites More sharing options...
