Cranks
I_RIDE_ECHO!
The tapers f***ed up on my Echo Forged (ISIS). Spend more and get some better cranks. I've got Try-All ISIS now :P
Yeah but they only get 'f**ked up' if you ride when the crank bolts come loose and that ruins the tapers. keep the bolts done up super tight and theres no problem at all. Which is the same as the square tapers... they're fine as long as their tight.
I'll wait for you reply after your ban is finished B)
Harder or easier than what? What were you previously running? If you had an 18T freewheel on the cranks before then going to a 16T will make the gearing a good bit lower (more spinny).
I haven't been running enything previously on these cranks because theyre new but my old one's were just onza cranks! Would it be the same gearing as the onza cranks???
CHIGS
