Sir_Hops_Alot Posted December 12, 2007 Report Share Posted December 12, 2007 I've just bled my back brake, done everything it said to do on the wiki and it works fine, but my master moves about a milimetre and the slave moves more. is this right or is there something wrong? Quote Link to comment Share on other sites More sharing options...
Ash-Trials Posted December 12, 2007 Report Share Posted December 12, 2007 Yeah does same to me but once i get it all set up seems to work fine Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted December 12, 2007 Author Report Share Posted December 12, 2007 Ok cheers . Also any ideas why i cant get my slave close enough to the wheel? Quote Link to comment Share on other sites More sharing options...
Ash-Trials Posted December 12, 2007 Report Share Posted December 12, 2007 hardley any pad left? Use TPA. Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted December 12, 2007 Author Report Share Posted December 12, 2007 Yeah the pads are only 3weeks old. How can i fix my cross threaded metal tpa? Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted December 12, 2007 Report Share Posted December 12, 2007 have you got a thin rim in a frame design more towards larger rims? Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted December 12, 2007 Author Report Share Posted December 12, 2007 No that i know of mate, i've had the pads set up fine before but now i can't get it to work. Quote Link to comment Share on other sites More sharing options...
I_RIDE_ECHO! Posted December 16, 2007 Report Share Posted December 16, 2007 No that i know of mate, i've had the pads set up fine before but now i can't get it to work.When you set your brakes up try putting a match stick in between the rim and the pads then tighten everything and take them out?? Well that is what i do enyway.CHIGS Quote Link to comment Share on other sites More sharing options...
