Is It Worth Getting A Cracked Frame ?
I mite be getting a monty 221ti frame
according to the last owner it has 3 cracks in it , one on the disc mount and two, quite near to each other on the bb . the person who has the frame now said that there are no cracks in it. if there are cracks how long do you think it will last ??
please leave lots of comments
thanks leon
Edited by trials-Leon
If you know someone who welds and heat treats aluminium for a living, do it.
If not DON'T.
I do, so if it's cheap enough, I would.
the frame is £25 i swapped it last nite for my t-pro and he gave me a front disc hub on echo rim aswell
by the looks of it , it isnt a crack but im going to get it welded just encase , but there is a crack on the disc mount, fo shaw !!
leon
Cracked disc mounts no big deal, as long as you don't run a disc.
Don't get the BB welded untill you are cirtain its a crack. The welding process geatly weakens the surrounding aluminium. If it is a crack though, its still gunna be much stronger than leaving a crack. Try to get it heat-treated if you get it welded, that'll help alot.
I rode a welded koxx for a good few months, and a mate rode it for another month or 2 with no problems. My Iolo's cracked too, and thats not even grown in about 2 or 3 months.
