Not Another High Bb Enquiry.....how Dull!
Rusevelt
I think its fair to say that whenever this question/enqury comes up, most of us favor the low bb (bottom bracket) and slate the high bb right! so my question is why is the GU typhoon the most sucessful high bb stock frame on the market where past high bb stock frames have failed? most of us slated the first generation high bb frames of KOXX, ZOO, and ADAMANT. so why has the Typhoon stood the test of time considering it is probably the most difficult frame to get use to? Oh yeah, isnt a high bb a slight cheating height advantage for sidehops because when on the backwheel, your effectively standing a few inches higher (before preloading to sidehop) than a low bb? is the GU wheelbase, chainstay, and headangle geometry spot on for such a high bb, or have most gu owners just gotten used to the geo over time? Is Damon Watson just a freak of nature by being an exceptional rider, or is does his bike play a big part of his massive riding....considering his past rides have been high bb bikes?
Edited by Rusevelt
I went from a Saracen (-5mm) to and Ashton (0mm) ti a Zoo (+5mm) to a GU (+60)
Each change felt like a progression, and going from the zoo to the GU was the biggest leap, found it hard to start with, as I kept riding with the front wheel way to high, and the bike is really skitty on the back wheel.
But once I had got used to it, it felt better.
The raised BB brings your hips forward, which gives your a better line to deliver the power.
It makes the big less stable on 2 wheels, but more refined and more easliy tuned on 1.
I dont think BBs should go higher than 60mm.
definately, riding along rails is damn hard now, on my control it just happened
I can't really comment, as I've got a T-Pro (+25?) - and that's all I've ever had...
But I've always thought that a really high - within reason - BB would help with more power for gaps...
Not sidehops - yes, you're higher off the ground to start with - but you still have to get the same amount higher than the wall to stick it.
Gaps - it would seem to me, that you just have a better line... Low BB - hips hit the bars if you lean and push at the same angle as a high... But with a high, you go over the bars, and further past. ...Resulting in more power. (Longer time of pressure on the takeoff point.)
^^^ So, pretty much what he said :P Hahaha.
(Bit more elaborated though.)
Yes, but most people who have a high BB would compensate by bringing the bars up too, so you are still likely to hit your bars, i know i did on my BT6 (+40mm)...
Adam
PS: High Bb sucks :P
Yeah i also noticed that Damon Watson has the most super stable backwheel control without the use of correction hops (apart from Balaey, Coustelliers, and co) ive seen from any rider and thats partly because when hes at the perfect backwheel balance point, i notice the bb axle line is sitting at 12 O clock position (which is the same feeling as standing directly on top of the backwheel tire). obviously riding along balance lines is harder because the higher centre of gravity on the bike so you have to change your foot pedal position by keeping your toes pointing inwards. anyway enough of the techincal jargon, i just figured that the Typhoon would have flaked outta fashion along the other deng high bb bikes, obviously i was sure wrong.
Edited by Rusevelt
high bb frames makes the thing in front of you look smaller and easier to get up as your higher... it may sound stupid but when i ride my mates zoo pitbul (low bb) a 40" wall looks about 50" compared to when im on my GU, iv had my GU for a year now and have got used to the balance issues and love it!! and considering im probs waaaay better on natty compared to street it cant be bad for ballance on 2 wheels lol, you all so have alot more clearence over stuff, which realy helps for natty and stuff as you can shunt over bigger things without gettin you bash stuck.... and on a normal wall unless you go at an angle your bash CANT actualy hit the wall... it also makes hoock easier as your feet arnt so tucked under the wall when you hit it ...if you get me? i hate loww bb (zoo etc) now, it feels like im riding my dads mountain bike... just feel bulky and heavy like theres 2 tone forks on it.. and i cant 'flick' it around... i quite like things in between though like czars.... but still prefer my GU :)
My A3 short is +60, and it manuals like a biatch :)
all 20"s are easy as f uc k to maual lol
all mods manual, but how can you have good rear wheel control and not be able to manual, thats a contradiction in its own right
Because the balance point for backwheel control and manuals on high bb bikes are different in terms of body position. you cant maintain good backwheel trials control if you contort/tuck your body in a typical manual postion. and its virtually impossible to manual with your frontwheel high and bars close to your chest.
To answer your question about damon....he is seriously just an amazing rider. When he started, he was on low bb bikes and was awesome on them. He was doing 50" sidehops on his onza t-rex when he got that.
Freak o nature, however i think high bb will help for sidehops, mine did anyway, however for anything else it wasnt as great. Anything that requires keeping the bike to back wheel well is better on a high bb!
thats my opinion.
typhoon int goin anywere!
its here too stay ;)
lol
its because its the most succsessful high bb frame Deng makes :)
and people know it has the edge over the old hifi's a1's pitbulls n all the resta the shizzna
so it jus got continued
:rolleyes:
as for the geometry
its true 2 wheel balance lines are harder then on low bb bikes
and backwheel, control is the same, bacause on low bb bikes i find u can bring the bars right into your chest.
but i jus enjoy the way high bb rides, iv grown to like it and it ideal for my type of riding, so iv jus sticked to it, i hardly tap anyway, so dunt matter to me :turned:
Think high bb frames are rank, and around 30 is where its at. I get on a gu and think im going to fall over bars because of the rise. I had one and kept it 2days. I think why the gu was such a hit was because it was such a unusally desgin at the time and people just thought it looked so cool and with so many riders these days not looking at geo and not paying so much attention to it but more going off what people say and the looks, couple that with the TGS style everyones bumming at the mo damon helped it along as hes a big street rider.
I think you'll find T-pros have about 50mm BB rise. :)
