How What To Drill Crank Bolt Out
Toby3448
Ok So to stop my cranks falling off i used lock tight but they have come mm loose and need to get the crank bolt out , is rounded slightly so cant get enough leverage on it , tried mole grips but to be honest mine were crap didnt work. so i feel drilling it out only option left. were can i get this done or can i use my drill wont i need a differ drill bit ?? im totally lost
Use the biggest easy out possible so you dont end up snapping it in the hole you have drilled. If possible, get another person to help you.
Stick the easy out in the hole and twat it in with a hammer. Stick a spanner over it, and get another person to keep on hitting the easy out while your undoing it so that it keeps on gripping the bolt and doesnt come loose. should come out piss.
Use them at work all the time for getting rusted in/rounded bolts out of moulding tools.
The shock from hitting the tap in should crack the loctite allowing you to get it out.
Have you tried sticking the allen key in and hitting it a couuple of times to try and loosen the threads?
Edited by Si-man
