Smallville Posted December 8, 2007 Report Share Posted December 8, 2007 Is there any way to make a Hope Pro 2 front hub "bolt on" instead of quickrelease? Quote Link to comment Share on other sites More sharing options...
The Duck Posted December 8, 2007 Report Share Posted December 8, 2007 (edited) Closest you'll get..(lets see if this link works)Edit: oooh! it does! Edited December 8, 2007 by Quackers Quote Link to comment Share on other sites More sharing options...
Ali C Posted December 8, 2007 Report Share Posted December 8, 2007 not without making a custom axle Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted December 8, 2007 Report Share Posted December 8, 2007 (edited) not without making a custom axleCant you just tap the current axle thats in there, M5? And use bolts??But Alic Know WAY more than me!!! Edited December 8, 2007 by Matt Gibson Quote Link to comment Share on other sites More sharing options...
The Duck Posted December 8, 2007 Report Share Posted December 8, 2007 Quote Link to comment Share on other sites More sharing options...
Ali C Posted December 8, 2007 Report Share Posted December 8, 2007 the hub doesnt have a conventional axle, it only has two end caps that support the bearing, when you do up your quick release that acts as the axle. Its a weight saving design.if you put bolts in, the wheel would wobble all over the shop in your forks (plus the end caps would just spin with the bolt as you tightened it. Quote Link to comment Share on other sites More sharing options...
The Duck Posted December 8, 2007 Report Share Posted December 8, 2007 I use one, and it works fine for me. Quote Link to comment Share on other sites More sharing options...
psycholist Posted December 8, 2007 Report Share Posted December 8, 2007 I've run skewers like this on my trials bike for years with no problems. Make sure you get ones with a 5mm allen key head though. 4mm head ones can't be done up tightly enough to keep the wheel on without rounding the bolt head. Quote Link to comment Share on other sites More sharing options...
JonMack Posted December 8, 2007 Report Share Posted December 8, 2007 Ali meant if you tap the "axle" and try and use bolts it wouldnt work. The allen key skewer would work fine. Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted December 8, 2007 Report Share Posted December 8, 2007 I heard on Section 7 or here that it could be done, Thats how long ago it was. 3-4 years agoBut yeah there nothing rong with quick releses. Do them up tight enough and make sure, (if its hope) You push it all the way back in. If you get me?? Quote Link to comment Share on other sites More sharing options...
Christophe' Posted December 8, 2007 Report Share Posted December 8, 2007 I heard on Section 7 or here that it could be done, Thats how long ago it was. 3-4 years agoBut yeah there nothing rong with quick releses. Do them up tight enough and make sure, (if its hope) You push it all the way back in. If you get me??that was the wankest post ive ever seentruly"I heard on section7" fooking laugh.nice joke Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted December 8, 2007 Report Share Posted December 8, 2007 NO i really did! Maybe my grammer was a bit out?!?! ARSE!!! Quote Link to comment Share on other sites More sharing options...
N Roach Posted December 8, 2007 Report Share Posted December 8, 2007 I thinks its possible, if you tap a thread into the hole. Quote Link to comment Share on other sites More sharing options...
basher Posted December 8, 2007 Report Share Posted December 8, 2007 I thinks its possible, if you tap a thread into the hole.Read the whole thread next time before you post Quote Link to comment Share on other sites More sharing options...
N.Wood Posted December 8, 2007 Report Share Posted December 8, 2007 TO SUM UP:Its not possible to tap a thread into each end and use a bolt, as Ali said they just have axle ends rather than solid axle.It is possible to use a bolt on skewer if you like. Quote Link to comment Share on other sites More sharing options...
Smallville Posted December 9, 2007 Author Report Share Posted December 9, 2007 The bolt on skewer is nearly the same as a quickrelease. I was more thinking of a real bolt, but as Ali said it seams hard to do. On the other hand my father got all the machines at work to be able to do an axel. So the quickrelease and the 20mm version is the same hub but with diffrent endcaps? Quote Link to comment Share on other sites More sharing options...
