jimmy1989 Posted December 4, 2007 Report Share Posted December 4, 2007 Hi,I have recently bought a Sherco 2.5 2002/03 and have set about replacing the little end. This has been done with no problems but have been unable to get the bike to start since. There doesnt seem to be any fuel getting to the sparkplug as its virtually dry when I take it out (it does have a couple of spots of fuel on but I thought it should be drenched?) I have taken the carb apart and this is definately getting fuel as the float bowl is full. There is definately a spark as well and have come to a dead end. Can anyone help as Im tempted to take the bike and roll it off a big hill at the moment. Only been out twice since purchase 3 months ago... James Quote Link to comment Share on other sites More sharing options...
BenLeacock™ Posted December 4, 2007 Report Share Posted December 4, 2007 Hi mate, this is Biketrials forum. There maybe some mototrials riders however your best option it to try trials central.Link >> Trials Central Quote Link to comment Share on other sites More sharing options...
chrisbikefix Posted December 4, 2007 Report Share Posted December 4, 2007 hi james, sounds a bit odd. Does it seem to have comprsion when you use the kick stand. I had a sherco once that for some reason got kinda blocked - undervacum causing it not to start. I would prob take it back where you got it from .. or to a dealer though, Quote Link to comment Share on other sites More sharing options...
matt rushton Posted December 4, 2007 Report Share Posted December 4, 2007 Should have got a Beta. Quote Link to comment Share on other sites More sharing options...
BENSPEED888 Posted December 5, 2007 Report Share Posted December 5, 2007 did you put the piston back in the right way round, are the rings the right way up? did you check the jets (idle and main), has the woodruf key in the flywheel sheared? Quote Link to comment Share on other sites More sharing options...
MadManMike Posted December 5, 2007 Report Share Posted December 5, 2007 Pedal? (Sorry, that was completely unhelpful!) Quote Link to comment Share on other sites More sharing options...
koxxtrials Posted December 5, 2007 Report Share Posted December 5, 2007 Should have got a Beta.beta are a absolute crap trials bike they have crap power heavier than any other trials bike and sound crap and cost loads Quote Link to comment Share on other sites More sharing options...
harmertrials Posted December 5, 2007 Report Share Posted December 5, 2007 Hi there mate, I have a sherco 2.9 2002 which lucky for me has had very few problems... But, I know this may sound odd... Have you checked the air filter? Because on one of my gassers I have had similar problems with my air filter, I would also check that you haven't cross threaded the spark plug when inserting it... Oh and also make sure the rad has a decent amount of coolant in it.Its hard to say what the problem is whithout actually seeing the bike itself, so maybe have a ring around a few shops (haven trials sport) for example because they deal with sherco.p.s. it could just be that dirt has got clogged up where you insert the spark plug... Quote Link to comment Share on other sites More sharing options...
koxxtrials Posted December 5, 2007 Report Share Posted December 5, 2007 Hi,I have recently bought a Sherco 2.5 2002/03 and have set about replacing the little end. This has been done with no problems but have been unable to get the bike to start since. There doesnt seem to be any fuel getting to the sparkplug as its virtually dry when I take it out (it does have a couple of spots of fuel on but I thought it should be drenched?) I have taken the carb apart and this is definately getting fuel as the float bowl is full. There is definately a spark as well and have come to a dead end. Can anyone help as Im tempted to take the bike and roll it off a big hill at the moment. Only been out twice since purchase 3 months ago... Jamesrecently have you messed about with the bike because that's what people sometimes do and then they can't get them to start your better off taking it malcolm rathmell sport or a local decent sherco dealer maybe it has something to do with the mixture of 2-stroke or most likely to be the spark plug try replacing it that should do the trick Quote Link to comment Share on other sites More sharing options...
Muel Posted December 5, 2007 Report Share Posted December 5, 2007 (edited) recently have you messed about with the bike because that's what people sometimes do and then they can't get them to start your better off taking it malcolm rathmell sport or a local decent sherco dealer maybe it has something to do with the mixture of 2-stroke or most likely to be the spark plug try replacing it that should do the trickDo you have any idea what your talking about? That Raga Rep of yours is going to be dust in about 2 weeks.He said there is a spark, that means the spark is fine.Have you checked the ignition timing? after checking for a spark etc and looking at the fueling side of things, that should be the next thing on your list.EDIT: Also, just because there is petrol in the float bowl doesn't meen it's coming up the main jet OK. Strip it down and use one of the breathers do blow through every fuel/air way. My TY was running really rich once because a tiny piece of the air filter clogged up on of the air ways. In a TY, the air mixes with the fuel before it comes up the main jet, using an emulsion chamber.You only get a little bit in, but it means that as the fuel goes through the main jet, it compresses slightly because of the air in it, so it squirts out of the main jet, which helps it to mix thoroughly in with the main air flow coming from the air box. Edited December 5, 2007 by El Muelio Quote Link to comment Share on other sites More sharing options...
koxxtrials Posted December 5, 2007 Report Share Posted December 5, 2007 (edited) Do you have any idea what your talking about? That Raga Rep of yours is going to be dust in about 2 weeks.He said there is a spark, that means the spark is fine.Have you checked the ignition timing? after checking for a spark etc and looking at the fueling side of things, that should be the next thing on your list.EDIT: Also, just because there is petrol in the float bowl doesn't meen it's coming up the main jet OK. Strip it down and use one of the breathers do blow through every fuel/air way. My TY was running really rich once because a tiny piece of the air filter clogged up on of the air ways. In a TY, the air mixes with the fuel before it comes up the main jet, using an emulsion chamber.You only get a little bit in, but it means that as the fuel goes through the main jet, it compresses slightly because of the air in it, so it squirts out of the main jet, which helps it to mix thoroughly in with the main air flow coming from the air box.my raga rep is the ultimate 125 trials bike have a look on B an B road and trials website and will maintain that until 2009 when the montesa 125 4rt but i doubt it will be much better my bike is so smooth Edited December 5, 2007 by koxxtrials Quote Link to comment Share on other sites More sharing options...
harmertrials Posted December 5, 2007 Report Share Posted December 5, 2007 my raga rep is the ultimate 125 trials bike have a look on B an B road and trials website and will maintain that until 2009 when the montesa 125 4rt but i doubt it will be much better my bike is so smoothI think you will find that he was reffering to your know how - Having the best bike out there means nothing, if you don't know how to maintain it properly it will run like a bag of spuds. Quote Link to comment Share on other sites More sharing options...
tom jersey Posted December 5, 2007 Report Share Posted December 5, 2007 Should have got a Beta.Yeh if the kid wanted a shit bike. Gas Gas for the win best trials bike ever. Quote Link to comment Share on other sites More sharing options...
wrongsideof40 Posted December 5, 2007 Report Share Posted December 5, 2007 (edited) Just a thought did you remove the reeds when you removed the head ? make sure they are seated correctly and like was said earlier piston, rings and compression. If these are 100% right and you are sure the carb setup is 100% correct then replace the plug if its still a no go the check the timming. Its all quite easy stuff to check and correct.Gas Gas for the win best trials bike ever. Your having a laugh.... Edited December 5, 2007 by wrongsideof40 Quote Link to comment Share on other sites More sharing options...
Muel Posted December 6, 2007 Report Share Posted December 6, 2007 Yamaha made the best trials bike ever, in the form of mine. I'm being serious! I have rideen GasGas's that just piss all over everything you ever point them at, but your constatly worried about them, and they aren't really any good if you like hooning around.I love going fast and jumping on my bike, which I can't do on a modern bike because of the shorter wheelbase.Don't tell me I should have got a motorcrosser, my bike is perfect, the only thing it needs is a bit more power, so I can pull 5th gear wheelies more easily. It's old, heavy, rattley, and not very powerful, but I would choose it over a modern bike any day because it's so much more fun to ride. Modern bikes are brilliant in competitions and at going up rock's and stuff, but shite at doing anything else, slow wheelies are a breeze, but fast ones sitting down are impossible.They are harder to do powerslides on as well, which I love doing on my bike.You can't sit down either with you wieght towards the front, so going round corners is a bit of a task.My TY does everything I want it to do, it just needs a bigger engine, (planned), and an extra gear. 6 just isn't enough.I could just get a trail bike, but they are too extreme, I my bike does everything. Even tarmac.One bad thing though, stoppies are impossible. Quote Link to comment Share on other sites More sharing options...
koxxtrials Posted December 6, 2007 Report Share Posted December 6, 2007 (edited) Yamaha made the best trials bike ever, in the form of mine. I'm being serious! I have rideen GasGas's that just piss all over everything you ever point them at, but your constatly worried about them, and they aren't really any good if you like hooning around.I love going fast and jumping on my bike, which I can't do on a modern bike because of the shorter wheelbase.Don't tell me I should have got a motorcrosser, my bike is perfect, the only thing it needs is a bit more power, so I can pull 5th gear wheelies more easily. It's old, heavy, rattley, and not very powerful, but I would choose it over a modern bike any day because it's so much more fun to ride. Modern bikes are brilliant in competitions and at going up rock's and stuff, but shite at doing anything else, slow wheelies are a breeze, but fast ones sitting down are impossible.They are harder to do powerslides on as well, which I love doing on my bike.You can't sit down either with you wieght towards the front, so going round corners is a bit of a task.My TY does everything I want it to do, it just needs a bigger engine, (planned), and an extra gear. 6 just isn't enough.I could just get a trail bike, but they are too extreme, I my bike does everything. Even tarmac.One bad thing though, stoppies are impossible.stoppies and wheelies on modern trials bikes are easy sit down wheelies all you do is rev it a little bit and then pop the clutch and sit on the back mud guard and stoppies are just like on a pushbike but with more weight have a look at some of my cowm quarry vids under sherco222cowm vids Edited December 6, 2007 by koxxtrials Quote Link to comment Share on other sites More sharing options...
jsy trials matt Posted December 6, 2007 Report Share Posted December 6, 2007 (edited) have u checked all the usuall stuff on the carb. ( are the jets clear, does the slide move freeley and do the floats move freeley as well ) HAVE YOU TURNED ON THE FUEL TAP!!!!jsy matt Yeh if the kid wanted a shit bike. Gas Gas for the win best trials bike ever.quite clearly not tom as rich still beats u on the sherco Edited December 7, 2007 by jsy trials matt Quote Link to comment Share on other sites More sharing options...
Fishy Posted December 6, 2007 Report Share Posted December 6, 2007 Mate, you sound like such a dick and talk such shit. Yeah, alright gassers are alright but seriously, stfu. Quote Link to comment Share on other sites More sharing options...
koxxtrials Posted December 6, 2007 Report Share Posted December 6, 2007 the raga 125 is the best Quote Link to comment Share on other sites More sharing options...
matt rushton Posted December 6, 2007 Report Share Posted December 6, 2007 beta are a absolute crap trials bike they have crap power heavier than any other trials bike and sound crap and cost loadsAnd you have a Gasgas. Tut tut tut. I hope your not planning on giving it any abuse. Quote Link to comment Share on other sites More sharing options...
harmertrials Posted December 6, 2007 Report Share Posted December 6, 2007 (edited) the raga 125 is the bestI think you will find that he was reffering to your know how - Having the best bike out there means nothing, if you don't know how to maintain it properly it will run like a bag of spuds. Edited December 6, 2007 by harmertrials Quote Link to comment Share on other sites More sharing options...
matt rushton Posted December 6, 2007 Report Share Posted December 6, 2007 the raga 125 is the bestIt only has a couple of gold bits on and thats it Quote Link to comment Share on other sites More sharing options...
basher Posted December 6, 2007 Report Share Posted December 6, 2007 the raga 125 is the bestWho really cares, its not what you got its how you ride it. Quote Link to comment Share on other sites More sharing options...
Muel Posted December 6, 2007 Report Share Posted December 6, 2007 stoppies and wheelies on modern trials bikes are easy sit down wheelies all you do is rev it a little bit and then pop the clutch and sit on the back mud guard and stoppies are just like on a pushbike but with more weight have a look at some of my cowm quarry vids under sherco222cowm vidsBalls. You have never ridden a TY, when you grow up and get strong enough to chuck one about, then you will know what I am talking about.Who really cares, its not what you got its how you ride it.I agree, I regularly beat the modern bike boys at competitions, well, some of them.I always beat the top guys to the next section though. Quote Link to comment Share on other sites More sharing options...
koxxtrials Posted December 7, 2007 Report Share Posted December 7, 2007 i have ridden a ty250 and they feel really heavy and yamaha now make scorpa engines and they turned out to be a pile of crap Quote Link to comment Share on other sites More sharing options...
