Mod Questions
mairomaster
I am going to buy an echo lite mod and I have 2 questions:
1. Could I use my old 170mm echo cranks? I know that it's better to use 160mm cranks on a mod, but right now I haven't enough money to buy them. I will use 18/12.
2. Could I put my echo control 4 bolts booster to the lite? I can buy echo team booster but I think echo control is better because it holds the frame on 4 points and the team hold it only on 2.
Sorry for my bad english. 10x for replayes.
170 are fine on mod....as are 160( what i use) so dont worry about that. smaller cranks just make it slightly harder to peddal ..hardly noticeable really
and the control booster will be fine
dave :)
My brother has 170mm Tensiles on his T-Lite, feels wierd but it's still OK. They need changing to 160mm.
Good choice of bike! All the pro's ride them, is it an 06? They were the best.
Here's mine: http://www.trials-forum.co.uk/forum/index....=106880&hl=
All the pics are all over the first page.
The cranks will be fine but its luck if the booster will fit, as it fits some frame and tyre combinations but not others and the tyre rubs. i believe you can get a echo team in 4 bolt if not just get a different one theres plenty of 4bolt boosters around.
I can get only some of Deng boosters because I am from Bulgaria and the trial shop here offers only deng parts... Does Echo team 4 bolt booster exists? I thought there are only 2 bolt team. Is there someone here who sometimes have tried to put echo control booster to echo lite frame with echo tyre?
