Ryan. Posted December 3, 2007 Report Share Posted December 3, 2007 Right,iv got sky broadband atm and so far it has been the biggest pile of shit. one minute theres a wireless signal one minute theres not.so i solved that problem by just plugging the cables into my laptop and pc...now im on the laptop atm but the pc is saying limited or no connectivity??? iv tried repairing the connection, system restore, re attaching all the cables etc etc.if anyone knows what i can do to sort this i would really appreciate it.thanks,Ryan. Quote Link to comment Share on other sites More sharing options...
Danny Posted December 3, 2007 Report Share Posted December 3, 2007 So basically theres no problem with your internet connection itself. Seams to be a wireless problem. Does it work ok if you sit right next to the router? Quote Link to comment Share on other sites More sharing options...
Shay Posted December 3, 2007 Report Share Posted December 3, 2007 the cable from what your router to your laptop? or the cable from the wall to your laptop? Make sure that you're trying to connect through your cabled lan connection and not your wlan. Quote Link to comment Share on other sites More sharing options...
Ryan. Posted December 3, 2007 Author Report Share Posted December 3, 2007 shit iv just realised iv made no sense whats so ever....in a nut shell..iv got my laptop AND pc plugged into the broadband box which then plugs into the phone plug...now, my laptop is connecting perfectly to the net but the pc is sayinig that it cant renew my ip address to connect? Quote Link to comment Share on other sites More sharing options...
Pashley26 Posted December 3, 2007 Report Share Posted December 3, 2007 (edited) Sheringham_trials said: shit iv just realised iv made no sense whats so ever....in a nut shell..iv got my laptop AND pc plugged into the broadband box which then plugs into the phone plug...now, my laptop is connecting perfectly to the net but the pc is sayinig that it cant renew my ip address to connect?Ok, i think that means your Ip address from the Router to the PC does not match...Open Msdos and type Ipconfig It will tell you what you ip address and wireless capiaabilities are...Write down you Ip address and go to yor Laptop/or pc if you can access the router....Then wireless internet connections, open Add to existing network, blah blah blah...While your computer is scanning for other wireless items do the same thing to your laptop and they Should match up...If not just open your router and click propeties through your pc, and check it is set up to find Ip addresses automaticly, i can't remember where this is but it's not hard !If not unplug your Router for 2 minuites to reset it (dont worry, codes and connections remain) that should fix the problem is the first one dosen't....Being a Mac guy that might be wrong, but i'm prety sure it's not ! Hope this helps....Jarrod Edited December 3, 2007 by Pashley26 Quote Link to comment Share on other sites More sharing options...
