BENSPEED888 Posted December 2, 2007 Report Share Posted December 2, 2007 going to look at a second hand gu typhoon today, anything i should look out for? i'm talking cracks, dents, stressed areas. Quote Link to comment Share on other sites More sharing options...
loser Posted December 2, 2007 Report Share Posted December 2, 2007 BENSPEED888 said: going to look at a second hand gu typhoon today, anything i should look out for? i'm talking cracks, dents, stressed areas.You kind of answered you own question there Just check over the whole of the frameCracks normal appear at the welds so pay attention to areas around welds.Dents aren't really that bad, unless there massive so don't worry if its got a coupleGu's are pretty solid, i doubt it will be cracked or dented badly Quote Link to comment Share on other sites More sharing options...
Mackay Posted December 2, 2007 Report Share Posted December 2, 2007 Try and check if the threads on the frame are fine for putting in bolts and bottom bracket, apart from that it's just common sense really about dents, scratches, cracks etc.hope i helped. Quote Link to comment Share on other sites More sharing options...
BENSPEED888 Posted December 2, 2007 Author Report Share Posted December 2, 2007 thanks guys, i'l give it a real good look over. Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted December 2, 2007 Report Share Posted December 2, 2007 (edited) ride it, if you cancheck if any things loose etc,cracks dents yup you got it Edited December 2, 2007 by speedyjustice Quote Link to comment Share on other sites More sharing options...
BENSPEED888 Posted December 2, 2007 Author Report Share Posted December 2, 2007 right, had a look at the bike, all looks good with the frame, heres the spec:06 typhoon frameecho forksecho isis cranks wth screw on chainring and bashdmr v8'smagura on reardeore disk up fronthope f hub with tryall rimgu rear hub with tryall rimecho bars and stemcan have it for £350, it has been used a bit, but not battered like. Quote Link to comment Share on other sites More sharing options...
Mackay Posted December 2, 2007 Report Share Posted December 2, 2007 a pretty good bike for the price, depending on condition on parts i would probably go for itmight want to consider changing the front brake Quote Link to comment Share on other sites More sharing options...
jacob l Posted December 3, 2007 Report Share Posted December 3, 2007 look for any stress areas and look for how many dents are in the down tube.also check the weld mainly on the reer end for cracks or chips Quote Link to comment Share on other sites More sharing options...
