Ill Try Again
kobikesmatt
read what i put in your other thread, your valadation chances are decreasing ... fast !
What you need to do is, before you put the image in, put [*] then put the url! [**] Do all of this with out spaces in between. When you put a different picture on, start on a different line. Hope this makes sense ?
* = img
** = /img
Sorry I couldnt actualy put them up due to the face i got this message tongue.gif
Start by putting you pictures on the interenet. Photobucket or any other picture host. Then you will get a direct link !
Copy this direct link. [ img ] Put this link inbetween [ /img ] ( you need to make sure there is no spaces between the [ and the i or the [ and the / ! Same on the other side ) Or you can use the Insert Image button.
Im sorry i can't actualy make it any simpler than this ?
Don't make more threads though, your just reducing risk of valadation !
Ben
Edited by benleacock
