Magura Barbed Fitting
Ash-Trials
How do i fit it?
I did some searches, tried boiling hose to soften it, running it over a candle, widening end with a hot skewer.
Every time i couldn't get it in. and with the skewer one it went in ok with a hammer but it just leaks.
Please can someone help as i am VERY pissed off :(
Edited by Ashkwil
Put the hoseing in a vice with some sticking out, dont do the vice up to much. Then hammer the fitting in moving more hoseing out of the vice if need be. I used one of the bench mate things as its wood.
Or you can get some magura fitting blocks or get a piece of wood chop it in half put the pieces back together and drill a 5mm hole i think it is then put the hoseing in and clamp it up and then hammer the fitting in.
