Ste Wilson Posted November 27, 2007 Report Share Posted November 27, 2007 (edited) ARGH it is so annoying! My front freewheel does no want to budge i have tried everything clamp vice vasaline.. is there anyway i can get it of or sill i have to spend like £20 at halfords thanks ste thanks ste Edited November 27, 2007 by trials ste Quote Link to comment Share on other sites More sharing options...
Alex@Flawless Bikes Posted November 27, 2007 Report Share Posted November 27, 2007 Get a freewheel tool, clamp it on so it will not slip, get a spanner on it, then the magic bit, get a VERY long pole on the end of the spanner!! I used my old t-comp frame for levage. It should come off, just keep trying that how i manged to get 3 of the fuc*ers off. Quote Link to comment Share on other sites More sharing options...
Muel Posted November 27, 2007 Report Share Posted November 27, 2007 Strip it down, pull all the pawls and springs off, lamp it up in the vice across the flats left by the missing pawls and twat the crank with a hammer. Quote Link to comment Share on other sites More sharing options...
Ste Wilson Posted November 28, 2007 Author Report Share Posted November 28, 2007 Strip it down, pull all the pawls and springs off, lamp it up in the vice across the flats left by the missing pawls and twat the crank with a hammer.loving the techincal bit haha thanks both of you! Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted November 28, 2007 Report Share Posted November 28, 2007 I used to lock the freewheel tool onto the crank with like a g-clamp type thing then put a big spanner on the tool but at an angle so that you make a wide angle V between the crank arm and the spanner. Place the assembly on the floor with the point of the v (the freewheel) raised off the floor and STAMP on the freewheel! Make sure you have some tough soled shoes on and it should work. Always did for me anyway... Quote Link to comment Share on other sites More sharing options...
