Sonny Clarke Posted November 27, 2007 Report Share Posted November 27, 2007 (edited) Right, i took out the RAM, hard drive and graphics card out of my family computer and put it in the PC i'm building just to test it. I then switched the graphics cards around putting the better one in my PC that i'm building. When i turned my PC on the first time the resolution and text was completely f*ucked. I tried changing it the simple way (right click, personalise, change resolution) but that didn't work. I then tried to Install the graphics card using the CD, that didn't work! I then tried to change it during the start up, i can't remember what i changed but now it doesn't start up. I have tried changing it back using F2 and F10 etc but this doesn't work. I use Windows, all help appreicated! Edited November 27, 2007 by Clarkey Quote Link to comment Share on other sites More sharing options...
wrongsideof40 Posted November 27, 2007 Report Share Posted November 27, 2007 Do it startup in safe mode ?. After the bios boot press F8 when its and select safe mode. Quote Link to comment Share on other sites More sharing options...
Sonny Clarke Posted November 28, 2007 Author Report Share Posted November 28, 2007 Come on someone must be able to help me! Quote Link to comment Share on other sites More sharing options...
poopipe Posted November 28, 2007 Report Share Posted November 28, 2007 put the graphics card that worked back in and hope.if that gets you back to normalstart all over again from the beginning - remembering to uninstall old graphics drivers and install new ones before swapping any hardware about Quote Link to comment Share on other sites More sharing options...
wrongsideof40 Posted November 28, 2007 Report Share Posted November 28, 2007 Do it startup in safe mode ?. After the bios boot press F8 when its and select safe mode.was trying to help, but need more info.. Quote Link to comment Share on other sites More sharing options...
