_Owen. Posted November 25, 2007 Report Share Posted November 25, 2007 try trashzen. they normally have good vids for helping techniques. Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted November 25, 2007 Report Share Posted November 25, 2007 (edited) this might help Youtube Video -> ">" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> Edited November 25, 2007 by speedyjustice Quote Link to comment Share on other sites More sharing options...
ilikeriding Posted November 25, 2007 Report Share Posted November 25, 2007 (edited) this might helpjust im not hitting the cable drum that hard, u flick your arms upwards bend down towards the rear wheel touchng assIsnt a tap where you hit the vertical/corner bit?some big taps herehttp://es.youtube.com/watch?v=u_eTkWONiRE Edited November 25, 2007 by afroman Quote Link to comment Share on other sites More sharing options...
Ash-Trials Posted November 25, 2007 Report Share Posted November 25, 2007 Yeah in the vid it was more a front to back switch really. Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted November 25, 2007 Report Share Posted November 25, 2007 i know it aint a proper tap but thats the move i 1st started to get the hang of before actually hitting a wall properly Quote Link to comment Share on other sites More sharing options...
Ross W. Posted November 25, 2007 Report Share Posted November 25, 2007 Find videos of the Cousts. - Last move -Gilles on the same rock. Quote Link to comment Share on other sites More sharing options...
chrishayton Posted November 25, 2007 Report Share Posted November 25, 2007 andrew vincent two. its on observed trials on their hosted video page, theres a bit with 3 taps in the middle, it taught me to tap properly Quote Link to comment Share on other sites More sharing options...
Peter Green Posted November 26, 2007 Report Share Posted November 26, 2007 film yourself tapping and you will see your mistakes Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted November 26, 2007 Report Share Posted November 26, 2007 this might helpjust im not hitting the cable drum that hard, u flick your arms upwards bend down towards the rear wheel touchng assTotally off topic, but whats the tune in that vid? I've been after it for ages. Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted November 26, 2007 Report Share Posted November 26, 2007 Totally off topic, but whats the tune in that vid? I've been after it for ages.clubbed to death by rob d Quote Link to comment Share on other sites More sharing options...
basher Posted November 26, 2007 Report Share Posted November 26, 2007 I ust to really struggle with taps and watching videos never helped for me as you cant see from another persons view what your doing wrong. So may be video yourself trying so you can compare. Also maybe try telling us what happens when you try and tap so we can say what you need to change.Ali c taught me how to tap when out on a ride and said what i needed to change and from then it clicked. Usually people arnt hitting the wall low enough and when they do there to stiff. You need to make sure your weight isnt to far over the back as usually that leads to your back wheel just slaming into the wall when you try and tap. hen you hit it with your front wheel maybe try aiming for something you want to let your arms come into you. I found this key as otherwise your to stiff, have your arms slightly bent before you hit and just let them come into as you hit it and you just fly up. As you tap bigger walls you need to hit it lower and lean forward more. Youll see on videos soem people tap smooth and some harsh this is usualy down to how much they exagerate there arm movement bringing it into them when they hit the wall, as it absorbs the hit. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted November 26, 2007 Report Share Posted November 26, 2007 Any good videos of mod tapping too? im in the same boat, i can do it but want to get better than 3 ft lol Quote Link to comment Share on other sites More sharing options...
basher Posted November 26, 2007 Report Share Posted November 26, 2007 (edited) Any good videos of mod tapping too? im in the same boat, i can do it but want to get better than 3 ft lolNo because its not right tapping a mod learn to bunnyhop youll get alot higher and will make your riding more fun. Seriously though learn to bunnyhop i would say. Tapping a mod is alot hard to pick up and hard to get any real height unless your on a long barge poll which im sure your on the short hydroxx arnt you. I found it wierd at first bunnyhoping but if you keep trying you eventually get the hang of it and its alot of fun and you can do some sweet moves and ride with a nice style. But tapping a mod is pritty much the same as stock, but i think you will struggle on mod to tap big on such a short frame. if you watch the top levels mod guys they either just go striaght to back wheel doing half turn or bunnyhop you never see them tapping. Edited November 26, 2007 by basher Quote Link to comment Share on other sites More sharing options...
chimpanzyyyy Posted November 26, 2007 Report Share Posted November 26, 2007 http://nopogo.meleeweb.net/videos/tutoriaux/marches.divxfrom nopogo Quote Link to comment Share on other sites More sharing options...
