74kingz Prediciment
Phil H
I have a slight problem which I don't exactly understand.
I replaced my middleburn 22T chain ring because it snapped. At the same time I fitted a 74 kingz tensioner. So I still have 22:18 ratio but just with a Kingz tensioner.
BUT my gear feels substancially harder (higher) and I don't understand why. I havent over tensioned the chain so its hard to push the cranks round and I can't really think of an explanation.
The only possible reaosns I can think of is that the chain rubbing against plastic makes alot of friction which makes it harder but im very doubtful of this as that would mean its just a crap design. Or its something to do with where it is positioned, like somehow preventing the wheel from spinning as easily :S
Can anybody solve this mystery? :)
Phil
Edited by Phil_Onza
How was your last tensioner, did you have good chain tension? , may be if you didnt that the change to good tension has made it feel like this. Thats only thing i can think of. My 74kings hasnt changed the feeling of my gear. Also cut up a hacksaw blade drill 2 hole in the pieces and fit to extra tension blades and the tension is amazing.
No I had a piece of crap DMR tensioner which I had sawn the wheel out, sawn half the body out of and had tensioning down via a BB cup being held between the frame and the tensioner haha.
Cheers, but extra tension isn't a problem at the moment just getting my beloved gear back! :(
Phil
If you have changed your chain to say... a KHE then that could make a difference. Also check your bb cause if it has stiffened up that could make more or difference.
I am running a KHE but I was running it before so shouldn't make a difference. Aha could be the BB, its fairly screwed up and it took a beating today with a hammer.
Actually now I come to thik of it, cranks spin normally backwards so can't be the BB
Phil
