Andrex Posted November 23, 2007 Report Share Posted November 23, 2007 Hi, I've had this tensioner for about two weeks nd its has gone weird. The chain heavily rubs on the tensioner, it tensions the chain but it is really stiff to pedal. My chain won't go any shorter and it wouldn't work if it was longer. Could this be my chain or the tensioner or something else? cheers Quote Link to comment Share on other sites More sharing options...
BRISA RIDER! Posted November 23, 2007 Report Share Posted November 23, 2007 alrite mate this problem is a common thing, happens when you run certin ratios of chain rings, change your front onne down 2 teeth and you should have enough slack to take out an extra link and your chain,tentioner,gear ratio should be right then you should have a smooth rideCheers Jamie. Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted November 23, 2007 Report Share Posted November 23, 2007 but he'll have a different gear and ride like a spacktard?!oil? Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted November 23, 2007 Report Share Posted November 23, 2007 but he'll have a different gear and ride like a spacktard?!oil?lol. Post a pic if you can so we can see how you've got it set up. Quote Link to comment Share on other sites More sharing options...
BRISA RIDER! Posted November 23, 2007 Report Share Posted November 23, 2007 hey I drop from 22 to 20 tooth all the time as iv seemd to break alot of chain rings latly..and to be honist i cant sey theres that much difrence and within 10mins am spot on..Jamie. Quote Link to comment Share on other sites More sharing options...
Andrex Posted November 23, 2007 Author Report Share Posted November 23, 2007 (edited) I'm running it on 22-18, Edited November 23, 2007 by Andy J Quote Link to comment Share on other sites More sharing options...
Andrex Posted November 23, 2007 Author Report Share Posted November 23, 2007 Can someone help me in what to do because please, it is really getting on my nerves that i paid for an over priced shitty bit of plastic that don't work properly Quote Link to comment Share on other sites More sharing options...
N.Wood Posted November 23, 2007 Report Share Posted November 23, 2007 Looks metal to me?Anyways, 1: Oil your chain2: Try and flatten out the 'roller' part. You have a sharp angle on the end of it which would cause unwanted friction. Quote Link to comment Share on other sites More sharing options...
Andrex Posted November 23, 2007 Author Report Share Posted November 23, 2007 Looks metal to me?Anyways, 1: Oil your chain2: Try and flatten out the 'roller' part. You have a sharp angle on the end of it which would cause unwanted friction.i can't really flatten it out because every time I do it will just move back when i pedal, even though the bolts are done up tight Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted November 23, 2007 Report Share Posted November 23, 2007 (edited) Are you sure you can't remove a complete link from the chain? That would help lots if you could... It's really designed to look like that when in use. Edited November 23, 2007 by monkeyseemonkeydo Quote Link to comment Share on other sites More sharing options...
Andrex Posted November 23, 2007 Author Report Share Posted November 23, 2007 Are you sure you can't remove a complete link from the chain? That would help lots if you could... It's really designed to look like that when in use.when i take a link out the chain is too short and the tensioner will not touch it. Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted November 23, 2007 Report Share Posted November 23, 2007 A chain can never be too short for trials (provided you can actually connect it together of course...) Quote Link to comment Share on other sites More sharing options...
scousertrials Posted November 23, 2007 Report Share Posted November 23, 2007 18 on front and 15 on back. will sort that out.A chain can never be too short for trials (provided you can actually connect it together of course...)Yeah!!! Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted November 24, 2007 Report Share Posted November 24, 2007 is it a new chain? when i got a new chain it was either really long like that or too short....but i gave it a few days (kept skipping ) and then i was able to get a link out...was still really tight though..now it's stretched a bit more it's fine so...go do some static stuff that doesn't involve rolling anywhere (or else it skips like a beasty b*****d..) Quote Link to comment Share on other sites More sharing options...
Greetings Posted November 24, 2007 Report Share Posted November 24, 2007 Is that a GU 06? If so, your answer is an 18:15 gear ratio. It requires ~377mm chainstays to keep the chain tension up. You should be able to get the chain fairly tight while having the tensioner fairly close to the frame. Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted November 24, 2007 Report Share Posted November 24, 2007 but he can't get an 18t chainring.........! Quote Link to comment Share on other sites More sharing options...
Greetings Posted November 24, 2007 Report Share Posted November 24, 2007 but he can't get an 18t chainring.........!Well, it says in his profile that he has Burns. Can't see a problem there? Quote Link to comment Share on other sites More sharing options...
Netherking Posted November 24, 2007 Report Share Posted November 24, 2007 Hi, I've had this tensioner for about two weeks nd its has gone weird. The chain heavily rubs on the tensioner, it tensions the chain but it is really stiff to pedal. My chain won't go any shorter and it wouldn't work if it was longer. Could this be my chain or the tensioner or something else? cheersAre you running the springs that came with the tensioner? if so go buy some Eclipse hack saw blades (the LIGHT BLUE ONES!) and customize the spring lenght, mines at 100mm and i got 18:16 gearing on a T-rex. remember to double up the springs also. hope this helpsHarry Quote Link to comment Share on other sites More sharing options...
Andrex Posted November 24, 2007 Author Report Share Posted November 24, 2007 Are you running the springs that came with the tensioner? if so go buy some Eclipse hack saw blades (the LIGHT BLUE ONES!) and customize the spring lenght, mines at 100mm and i got 18:16 gearing on a T-rex. remember to double up the springs also. hope this helpsHarryyeah I've got the normal ones, I'll try that How much are the blades, I'm assuming I can get them from any DIY store. Quote Link to comment Share on other sites More sharing options...
