john.p Posted November 20, 2007 Report Share Posted November 20, 2007 (edited) Hey Hey Hey Whats the diffrence between a freewheel and an tesioner ?? I think its them two oh welll i will see if i get feedback . Sorry if anything is spelt wrong i carnt find the spell checker From JP Edited November 20, 2007 by john.p Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted November 20, 2007 Report Share Posted November 20, 2007 both completly different components dude Quote Link to comment Share on other sites More sharing options...
john.p Posted November 20, 2007 Author Report Share Posted November 20, 2007 both completly different components dude i thourght they were what is a freewheel then?? i know what a tensioner isfrom jp Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted November 20, 2007 Report Share Posted November 20, 2007 Freewheel: ratchet based system ( usually ) on a bike that lets the bike freewheel ( hence the name )tensionre: Tensions the chain when running Single speed, or can provide additional tension in a geared system to stop drivetrain from skipping Quote Link to comment Share on other sites More sharing options...
john.p Posted November 20, 2007 Author Report Share Posted November 20, 2007 Freewheel: ratchet based system ( usually ) on a bike that lets the bike freewheel ( hence the name )tensionre: Tensions the chain when running Single speed, or can provide additional tension in a geared system to stop drivetrain from skippingok thank you im new at trials and i just wonderd what they were up first i thought they were the same thing Quote Link to comment Share on other sites More sharing options...
joshball Posted November 20, 2007 Report Share Posted November 20, 2007 ok thank you im new at trials and i just wonderd what they were up first i thought they were the same thingDont worry about that we all learned sometime mate!What bike you ride? Quote Link to comment Share on other sites More sharing options...
ibi123 Posted November 20, 2007 Report Share Posted November 20, 2007 If you still dont get it its basically the cog that allows the chain to go one way but not the other. Most bikes have them on the rear hub but some trials bikes have them on the front. Lets jsut say if you did not have one when you stopped pedaling the wheel would just lock.Hope this clears things up a bit it you had not already grasped it. Quote Link to comment Share on other sites More sharing options...
Greetings Posted November 20, 2007 Report Share Posted November 20, 2007 Google is a good friend. Every time I don't know what something is, I just use Google's image search. Works almost every time...That's what a commonly used trials freewheel looks like. Usually though, they've got 18 teeth. Quote Link to comment Share on other sites More sharing options...
monty freek Posted November 20, 2007 Report Share Posted November 20, 2007 a freweel is the thing that cliks when you stop pedaling a chain tug AKA tenchana is the thing that stops youre chain from geting loose Quote Link to comment Share on other sites More sharing options...
john.p Posted November 21, 2007 Author Report Share Posted November 21, 2007 Dont worry about that we all learned sometime mate!What bike you ride?i ride a freshly sprayed echo pure 04 looks amazing rides amazing some of the spec : echo pure frame hs 33 back avid mech front disc echo bars (not sure what type)monty stem some wheels middel burn crank dmr v8 peddelshope pro 2 ( i think i know its hope) front hub dmr crappy tensioner echo forks there you go i hope to go for one of these rides one day just so i can meet new people!!i am new though i carnt pause hop yet i can side hop ,get up on walls easy !from jp Quote Link to comment Share on other sites More sharing options...
joshball Posted November 21, 2007 Report Share Posted November 21, 2007 i ride a freshly sprayed echo pure 04 looks amazing rides amazing some of the spec : echo pure frame hs 33 back avid mech front disc echo bars (not sure what type)monty stem some wheels middel burn crank dmr v8 peddelshope pro 2 ( i think i know its hope) front hub dmr crappy tensioner echo forks there you go i hope to go for one of these rides one day just so i can meet new people!!i am new though i carnt pause hop yet i can side hop ,get up on walls easy !from jpDont use the term pause hop use static hop!Good set up! Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted November 21, 2007 Report Share Posted November 21, 2007 a freweel is the thing that cliks when you stop pedaling a chain tug AKA tenchana is the thing that stops youre chain from geting looseWhat the f**ks that? Dude, sort your god damn spelling out. Quote Link to comment Share on other sites More sharing options...
john.p Posted November 21, 2007 Author Report Share Posted November 21, 2007 Dont use the term pause hop use static hop!Good set up!ok then i need help learning to static hop ! yer i think its a good set up and its my starter bike so im quite proud i will put some picks up when i have my stem back some how i made my stem only have 1 bolt through so some ones tapping it and putting a bolt through hopefully it will be safer Quote Link to comment Share on other sites More sharing options...
joshball Posted November 21, 2007 Report Share Posted November 21, 2007 (edited) ok then i need help learning to static hop ! yer i think its a good set up and its my starter bike so im quite proud i will put some picks up when i have my stem back some how i made my stem only have 1 bolt through so some ones tapping it and putting a bolt through hopefully it will be saferGo on youtube and type in ryan leech tutorials!Orwww.Trashzen.com (beast of a website)Hope i helped!Echo.JoshX-x-X Edited November 21, 2007 by echo.josh Quote Link to comment Share on other sites More sharing options...
john.p Posted November 21, 2007 Author Report Share Posted November 21, 2007 Go on youtube and type in ryan leech tutorials!Orwww.Trashzen.com (beast of a website)Hope i helped!Echo.JoshX-x-X i am goin to do that know !! thanx i need all the help i can get i think its a good job i started young Quote Link to comment Share on other sites More sharing options...
joshball Posted November 22, 2007 Report Share Posted November 22, 2007 i am goin to do that know !! thanx i need all the help i can get i think its a good job i started youngHow old are you? Quote Link to comment Share on other sites More sharing options...
john.p Posted November 22, 2007 Author Report Share Posted November 22, 2007 How old are you?i am 13 years old !!from jp Quote Link to comment Share on other sites More sharing options...
Mr_Gu Posted November 23, 2007 Report Share Posted November 23, 2007 Dont use the term pause hop use static hop!Good set up! He is 13 years old man. So thats why his spelling goin to be crap.jamie Quote Link to comment Share on other sites More sharing options...
john.p Posted November 23, 2007 Author Report Share Posted November 23, 2007 He is 13 years old man. So thats why his spelling goin to be crap.jamieyep hes true!! ^^ Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted November 23, 2007 Report Share Posted November 23, 2007 yep hes true!! ^^No it's not, age is no reason to be illiterate ( to a degree) i'm almost 16 and still can't manage a full sentence without a mistake where as there are some people younger than me that can spell much better than me. Quote Link to comment Share on other sites More sharing options...
john.p Posted November 23, 2007 Author Report Share Posted November 23, 2007 No it's not, age is no reason to be illiterate ( to a degree) i'm almost 16 and still can't manage a full sentence without a mistake where as there are some people younger than me that can spell much better than me.yer i just carnt spell some words and make a full sentence properly!!from jp Quote Link to comment Share on other sites More sharing options...
