Tom_ Posted November 19, 2007 Report Share Posted November 19, 2007 So i havnt riden for a week or so as iv been waiting on my new frame, my bike has been kept in a shed outside so it will have got very cold, so i would asume my maggy has at some point frozen.Now i just fitted it to my new bike, pulled the lever and the pads moved into the rim as normal. then they stayed there, the cylinders stayed extended and the lever just flaps about. Iv ajusted tpa, and everything but nothing sorts it. I dont have enough money for a new one......any ideas? Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted November 19, 2007 Report Share Posted November 19, 2007 Is it a water bleed? Is where you live cold? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted November 19, 2007 Report Share Posted November 19, 2007 whack some lube on the pistons Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted November 19, 2007 Report Share Posted November 19, 2007 what i would do is bleed the brake with mineral oil........opperate the lever so the pistons lube up ......then if u like ur water bleeds re bleed it with water......if your cycles is out side in the shed add antifreeze to your bleeding water.that will indeed sort your problems out Quote Link to comment Share on other sites More sharing options...
Broomer Posted November 19, 2007 Report Share Posted November 19, 2007 my bikes spent that last 2 winters in a shed with a water bleed, still as good as it was on day one. i dont think the weathers your problem. Quote Link to comment Share on other sites More sharing options...
Ryan Blackwell Posted November 19, 2007 Report Share Posted November 19, 2007 (edited) I think the same thing has happend to mine as my cylinders are so lazy now they dont really return and when i pedal hop they just rub. Edited November 19, 2007 by baseboy Quote Link to comment Share on other sites More sharing options...
JoNnY__Mc Posted November 19, 2007 Report Share Posted November 19, 2007 (edited) Dum Dum Dum... Another one bites the dust!!!!edit: On a more serious note, Bleed it with water and antifreeze... and get some 3 in one oil on the pistons to lube them up abit Edited November 19, 2007 by JoNnY__Mc Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted November 19, 2007 Report Share Posted November 19, 2007 i had one that just seized up proper....2nd hand slaves cost 'owt on here mind Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted November 19, 2007 Report Share Posted November 19, 2007 http://www.trials-forum.co.uk/wiki/Fixing_...ra_lazy_pistons Quote Link to comment Share on other sites More sharing options...
