Tom3bar Posted November 14, 2007 Report Share Posted November 14, 2007 Hello all,I'm new to the 4-bolt and the new style magura.I have it with a grind echo rim + echo pads... it just don't work as i want it to work!I've installed it pretty close to the rim... I'm playing with the TPA, but it slipps... and the magura lever is really annoying - it's just coming to close to the bars!I have a zoo! lever but if i install it the magura goes berserk! (may need to rebleed it with the zoo! lever but i don't want to - it's brand new!)Any help, suggestions, info and tips will be greatThank you and sorry if i nag about the maggies, again!Tom. Quote Link to comment Share on other sites More sharing options...
wrongsideof40 Posted November 14, 2007 Report Share Posted November 14, 2007 Hi Im no expert but it sounds like there is air in the system or the gap is to big between the rim and the pads, a bleed may be the only way. Also make sure that the pads are hitting the rim parallel and at the same time on both sides when the lever is pulled. Set the pads up with the TPA fully out cos this shouldnt be used for setting them up its only a quick way of adjusting your pads while out on a ride until you get the chance to adjust them properly with tools. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Ryan. Posted November 14, 2007 Report Share Posted November 14, 2007 sounds like you've ke-buggered your TPA, best off getting a 74kingz replacement...also you're gonna need to re-bleed the brake for the zoo lever. Wouldn't woory though water bleeds are mint if you do em right Quote Link to comment Share on other sites More sharing options...
Tom3bar Posted November 14, 2007 Author Report Share Posted November 14, 2007 I see....Thanks for the replies.I look into it, it is installed o.k, parallel and pretty close to the rim but it not gripping it enough - could it be bcs it a new rim and pads??Also i have a control booster, and it won't fit!!Is there a known problem with the Control Booster and the ST-1 frame??Thanks alot,Tom. Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted November 14, 2007 Report Share Posted November 14, 2007 i think that your pads may need some bedding in,i'd just ride normally for a hour or so and the pads should start working then .sorry i cant help with your frame/booster problem.steve Quote Link to comment Share on other sites More sharing options...
Netherking Posted November 14, 2007 Report Share Posted November 14, 2007 I see....Thanks for the replies.I look into it, it is installed o.k, parallel and pretty close to the rim but it not gripping it enough - could it be bcs it a new rim and pads??Also i have a control booster, and it won't fit!!Is there a known problem with the Control Booster and the ST-1 frame??Thanks alot,Tom.coust pads in CNC backings are BEAST, i was riding in the rain yesday and they still hold fine (with a pretty harsh grind), does it feel spongey?? if so bleed it, Quote Link to comment Share on other sites More sharing options...
Jimmy_k Posted November 14, 2007 Report Share Posted November 14, 2007 When you pull the lever the pads should move instantly, if there is a delay then that is your problem, there is air in the brake and it needs bleeding. Quote Link to comment Share on other sites More sharing options...
Tom3bar Posted November 14, 2007 Author Report Share Posted November 14, 2007 There is NO delay, but they do not move completely simultaneously... Hmmm.... about the booster - anyone? Thx Tom Quote Link to comment Share on other sites More sharing options...
MadManMike Posted November 14, 2007 Report Share Posted November 14, 2007 One moves before the other or quicker than the other? Still sounds like air to me... I'm no expert but they should be instant. Quote Link to comment Share on other sites More sharing options...
Fishy Posted November 14, 2007 Report Share Posted November 14, 2007 There is NO delay, but they do not move completely simultaneously... Hmmm.... about the booster - anyone? Thx TomYou got pictures? What do you mean it doesn't fit? Is the spacing out? Quote Link to comment Share on other sites More sharing options...
Tom3bar Posted November 15, 2007 Author Report Share Posted November 15, 2007 You got pictures? What do you mean it doesn't fit? Is the spacing out?I don't have a picture right now, but when i try to install the booster, it touches the pad!So i can't adjust it since it is touching it...Hope i make sense Tom. Quote Link to comment Share on other sites More sharing options...
